Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
I would like an updated FFMPEG release in vmix 18. FFMPEG 3.x also supports Intel QUICKSYNC, but vMix 17 still uses release 2.8.
Since Graphic cards nowadays use a minimal of 2 slots, we need tower PC's to get all cards mounted. However when using quicksync we could build smaller units without grapics card.
I managed to update the ffmpegformats.xml and replaced ffmpeg myself. Recording in ffmpeg format hardly used additional CPU. However, i could not stream anymore since LIBFAAC was missing. I could not find a way to get live streaming using acc instead of libfaac (or other ways to influence the stream ffmpeg command)
It would be great if vMix 18 would use ffmpeg 3 with quicksync support.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 75 time(s) in 57 post(s)
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Joined: 4/16/2015(UTC) Posts: 17  Location: São Bernardo do Campo - SP - Brasil Thanks: 17 times Was thanked: 1 time(s) in 1 post(s)
++++1 and h265 encode suport for new nvidia cards 960 970 980 1060 1070 1080
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
+1 for an update to FFMPEG with Intel Quick Sync enabled.
It would also be a gigantic benefit for my application to enable FFMPEG to generate a MOV timecode track based on the current system time. (FFMPEG can generate the timecode track, the problem is specifying the track's start time dynamically).
As a test I simply replaced the FFMPEG.exe binary (Windows 10) installed with vMix for the build of FFMPEG.exe 3.3.3 by Zeranoe. I was then able to modify vMix's ffmpegformats.xml file as follows and successfully leverage Quick Sync with an Intel NUC6i7KYK NUC for reduced GPU and CPU loads.
For a given <format> <video codec="h264_qsv"> ... <command>-pix_fmt nv12
The "h264_qsv" codec invokes Quick Sync if FFMPEG has been built with libmfx. The nv12 pixel format is required by Quick Sync.
 1 user thanked rickb for this useful post.
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Nowadays FFMPEG version is already 4.0.2. Support for Intel Quick Sync Video give also nice encoding performance improvement.
Please update FFMPEG version and enable Intel Quick Sync Video support!
Indrek
 1 user thanked vvcvvc for this useful post.
Big +1 for the FFMPEG new version, and for the QuickSync...
 1 user thanked pba for this useful post.
Joined: 9/20/2015(UTC) Posts: 43   Location: Hyderabad Thanks: 87 times Was thanked: 22 time(s) in 12 post(s)
 1 user thanked vijay6672 for this useful post.
Joined: 8/11/2018(UTC) Posts: 60   Thanks: 33 times Was thanked: 6 time(s) in 6 post(s)
 1 user thanked ThomasK for this useful post.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Why don't you just use EXTERNAL to feed the FFMPEG version of your choice with your own commands? Or NDI since FFMPEG now supports NDI feeds ? vMix is so "flexable", it brings everything you need to do whatever you want. Don't wait for such new features, create them yourselves! It's so easy!
