Stream Output options - upd mpeg2 transport stream
hello, following the FAQ at: https://www.vmix.com/kno...-transport-stream-or-udpi managed (quite ...) to stream an mpeg2 transport stream to an external device using the ffmpeg application in the streaming folder of vmix. the command i run (in that folder) is: ffmpeg.exe -f dshow -i video="vMix Video" -f dshow -i audio="vMix Audio" -c:v mpeg2video -b:v 20M -r 25 -async 1 -c:a mp2 -f mpegts udp://linux_encoder_ip:18000 but on remote site (i check with avplay://@18000) i can see only a color bar video with no audio .... what am i doing wrong? PS: vmix is with external enabled (black magic) and a video (with audio) was running in PGM out ..... thanks allegfede attached the following image(s):  color bars no vmix pgm.jpg (1,574kb) downloaded 9 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
mhh, my SD version has only 1 external renderer, and i use it to render on black magic output. Can directshow still intercept that audio/video stream?
