elpejo
#1 Posted : Tuesday, September 25, 2018 2:45:32 PM(UTC)
elpejo
Hi, I have a problem. I have in vmix connected 3 cameras in 1080 50i, the vmix, a geforce 1050 ti, and a decklink duo 2, all set to 1080 50i. when the signal is played by the geforce by hdmi, it makes me a little strobe, but when I play with the decklink by sdi the video comes out fluid, what could it be?
#2 Posted : Tuesday, September 25, 2018 3:38:35 PM(UTC)
What display ? A computer monitor? A TV set ? A Videoprojector ? A field monitor ?
Make sure the display supports 50i or 50Hz (or 25 Hz)
Very few computer monitors support interlaced signals as computer are progressive by default.
Guillaume
PS: please remove the other identical post you did. Do not spam this forum !!!
elpejo
#3 Posted : Tuesday, September 25, 2018 4:22:01 PM(UTC)
elpejo
THANKS DWAN. THE SIGNAL GO TO A TEM 1 M/E. the atem is set in: 1080 50I and the nvidia out is set on 1080 25 hz. in this case, the decklink works so fine
#4 Posted : Wednesday, September 26, 2018 12:19:12 AM(UTC)
To ensure the correct broadcast standard, you will need to use the Decklink output when connecting to the ATEM.
The fullscreen output is intended for displays only.
#5 Posted : Wednesday, September 26, 2018 4:27:11 AM(UTC)
I got this to work fine with an HDMI out and an ATEM. Thing is to use a splitter on HDMI out, set the nVidia HDMI OUT for 50Hz (or 25 Hz, it might vary), connect a display (TV set or field monitor) that shows 1080i50 for the source and THEN, finally, connect the splitter's second port to the ATEM.
Alternative is to use something like a Decimator or equivalent
Obviously as Martin said using the Decklink Duo 2 is another working option.
Guillaume
