elpejo
#1 Posted : Tuesday, September 25, 2018 2:45:32 PM(UTC)
elpejo
Hi, I have a problem. I have in vmix connected 3 cameras in 1080 50i, the vmix, a geforce 1050 ti, and a decklink duo 2, all set to 1080 50i. when the signal is played by the geforce by hdmi, it makes me a little strobe, but when I play with the decklink by sdi the video comes out fluid, what could it be?
#2 Posted : Tuesday, September 25, 2018 3:38:35 PM(UTC)
What display ? A computer monitor? A TV set ? A Videoprojector ? A field monitor ?
Make sure the display supports 50i or 50Hz (or 25 Hz)
Very few computer monitors support interlaced signals as computer are progressive by default.
Guillaume
PS: please remove the other identical post you did. Do not spam this forum !!!
elpejo
#3 Posted : Tuesday, September 25, 2018 4:22:01 PM(UTC)
elpejo
THANKS DWAN. THE SIGNAL GO TO A TEM 1 M/E. the atem is set in: 1080 50I and the nvidia out is set on 1080 25 hz. in this case, the decklink works so fine
#4 Posted : Wednesday, September 26, 2018 12:19:12 AM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
To ensure the correct broadcast standard, you will need to use the Decklink output when connecting to the ATEM.
The fullscreen output is intended for displays only.
#5 Posted : Wednesday, September 26, 2018 4:27:11 AM(UTC)
I got this to work fine with an HDMI out and an ATEM. Thing is to use a splitter on HDMI out, set the nVidia HDMI OUT for 50Hz (or 25 Hz, it might vary), connect a display (TV set or field monitor) that shows 1080i50 for the source and THEN, finally, connect the splitter's second port to the ATEM.
Alternative is to use something like a Decimator or equivalent
Obviously as Martin said using the Decklink Duo 2 is another working option.
Guillaume
