Could not login to IBM Cloud Video
 What is happening with this host?
Start with the basics. Please check your username and password works on the IBM service using their interface. Then setup a stream as a custom destination. If all OK there, setup a stream again using the presets. If not OK at any stage report it back here with troubleshooting detail. You need to include as much info as possible when reporting an issue. Simply showing an error is not enough for anyone to help you.
ask wrote:Start with the basics. Please check your username and password works on the IBM service using their interface. Then setup a stream as a custom destination. If all OK there, setup a stream again using the presets. If not OK at any stage report it back here with troubleshooting detail. You need to include as much info as possible when reporting an issue. Simply showing an error is not enough for anyone to help you. I login normally, as in the IBM web site, in the vMix. Same data. I used another account that I have, I verified the firewall, internet, and the problem still on. One thing as an extra: I install vMix after formatted the PC and install the drivers. When I logged in the software (vMix) gave me that error. I thought it was like "IBM is having an updating in its web site, that's why this error", but the days passed through, and it wasn't the problem. Thank you for answer.
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
This error usually means Windows is not up to date. IBM recently changed the security on their streaming sites to require a newer version of encryption.
Make sure all latest windows updates are installed, remove any 3rd party virus scanners and try again.
Martin vMix
admin wrote:Hi,
Martin vMix Oh... That might be! I update Windows and I'll tell you how it was... Thank you, Martin.
Yes, it was that! Now it works, thank you for the help!
