	3rd Party Software and Development
	vMix Virtual Control Surface 3.0 iPad app [Now Available!]
 Joined: 2/27/2013(UTC) Posts: 312  Thanks: 8 timesWas thanked: 78 time(s) in 43 post(s)
                The vMix Virtual Control Surface version 3.0 is now available. Here are the release notes for version 3.0 Purchase Link:https://itunes.apple.com...surface/id978932322?mt=8 3.0 Release Notes ****Special thanks to David Peltz (aka David_in_Philly on vMix Forums) for features & Ux consulting***** IP Connection: 1. Connect button added to home screen. Connection is initiated when connect button is pressed instead of the closing of the keyboard. 2. IP address of previous session is now saved in the IP address field. 3. Release notes link added. Video Window: 1. Inputs increased from 12 inputs to 48 inputs. Additional inputs are accessed by swiping the input area left and right. 2. 4 transition buttons are now labeled and reflect your transition selections in vMix 3. Function buttons are now labeled F1, F2, F3 and F4. Function buttons correlate to shortcuts setup within vMix using the "SurfaceF1" key. 4. Input labels are now 2 lines to accommodate longer input titles. Audio Window: 1. Inputs increased from 12 inputs to 48 inputs. Additional inputs are accessed by swiping the input area left and right. 2. Mute/Enable button graphic changed to better represent an audio mixer mute button. 3. Input labels are now 2 lines to accommodate longer input titles. 4. Audio channels can now be soloed by pressing and holding the mute button. After about a second, the mute/enable button will flash once, indicating that solo has been enabled or disabled. The soloed channel title background will change to orange. The soloed inputs will be listed below the vMix logo. 5. Audio bus assignments can now be programmed by pressing and holding the input title. A window will pop up that allows the Master, A and B buses to be toggled on/off. 6. The audio bus assignments are now displayed below the title of the input. * Users may have an inconsistent and laggy experience if iPad's wifi signal is weak.    |
              6 users thanked thecloudmediagroup for this useful post. |  |
 Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, DenmarkThanks: 22 timesWas thanked: 17 time(s) in 16 post(s)
                Fantastic app, can only recommend it! :) |
 Joined: 10/1/2016(UTC) Posts: 117 Thanks: 88 timesWas thanked: 52 time(s) in 31 post(s)
                Thanks for all the updates in the latest ios download - it goes full screen now and works great on our large screen iPad pros! We like using this when we do on-the-road setups with our laptop vmix systems. Quick setup and it just works ;) |
                I test it and i like it very much. but i miss replay control is this in the pipe line ??
 Thanks: 2 timesWas thanked: 1 time(s) in 1 post(s)
                Bad news for me ipad mini(ipad mini 1) support gone. |
 Thanks: 77 timesWas thanked: 32 time(s) in 31 post(s)
                Do persons who purchased the older version have to purchase the new version, or do we get a free update
                There may be an insignificant bug, the master audio indicator light does not seem to follow the VMIX software master audio's condition if changed from the VMIX software. |
 Thanks: 5 timesWas thanked: 1 time(s) in 1 post(s)
                thecloudmediagroup wrote:The vMix Virtual Control Surface version 3.0 is now available. Here are the release notes for version 3.0 Purchase Link:https://itunes.apple.com...surface/id978932322?mt=8 3.0 Release Notes ****Special thanks to David Peltz (aka David_in_Philly on vMix Forums) for features & Ux consulting***** IP Connection: 1. Connect button added to home screen. Connection is initiated when connect button is pressed instead of the closing of the keyboard. 2. IP address of previous session is now saved in the IP address field. 3. Release notes link added. Video Window: 1. Inputs increased from 12 inputs to 48 inputs. Additional inputs are accessed by swiping the input area left and right. 2. 4 transition buttons are now labeled and reflect your transition selections in vMix 3. Function buttons are now labeled F1, F2, F3 and F4. Function buttons correlate to shortcuts setup within vMix using the "SurfaceF1" key. 4. Input labels are now 2 lines to accommodate longer input titles. Audio Window: 1. Inputs increased from 12 inputs to 48 inputs. Additional inputs are accessed by swiping the input area left and right. 2. Mute/Enable button graphic changed to better represent an audio mixer mute button. 3. Input labels are now 2 lines to accommodate longer input titles. 4. Audio channels can now be soloed by pressing and holding the mute button. After about a second, the mute/enable button will flash once, indicating that solo has been enabled or disabled. The soloed channel title background will change to orange. The soloed inputs will be listed below the vMix logo. 5. Audio bus assignments can now be programmed by pressing and holding the input title. A window will pop up that allows the Master, A and B buses to be toggled on/off. 6. The audio bus assignments are now displayed below the title of the input. * Users may have an inconsistent and laggy experience if iPad's wifi signal is weak.    |
                hi, do I have to buy In each update. I did buy The previous version |
                lostad wrote:Bad news for me ipad mini(ipad mini 1) support gone. I’m not aware why that would happen. I’ll try to look into this |
              1 user thanked thecloudmediagroup for this useful post. |  |
                Joeboe wrote:Do persons who purchased the older version have to purchase the new version, or do we get a free update
 Free update! |
                TheIdol wrote:There may be an insignificant bug, the master audio indicator light does not seem to follow the VMIX software master audio's condition if changed from the VMIX software. I’ll take a look into that. Thanks for the report. |
                Originally Posted by: elpejo  how update? thanks
 You should be able to update it in the Apple App Store! |
                I keep trying, but with no luck...maybe i am doing something wrong.... |
                how update a windows version?
                Can't even get to download....I get the site, but no way to get this app downloaded..... |
                Why do not they do an app for android since much we use more android please friend..... |
 Thanks: 6 timesWas thanked: 9 time(s) in 5 post(s)
                Originally Posted by: djlyds  Why do not they do an app for android since much we use more android please friend..... I agree! A Android app would be amazing! Many more people use Android devices.  :) |
 Joined: 5/29/2019(UTC) Posts: 1  Location: Chilliwack |
                Is this app still available? Doesn't seem to show up in apple search.
