mjgraves
#1 Posted : Tuesday, July 31, 2018 2:48:26 PM(UTC)
mjgraves
Today I tried connecting a Logitech C922 Pro Stream webcam to the latest vMix release (21.0.0.53.) I wanted to evaluate the latency introduced by using H.264 encoding.
The C922 does support H.264 encoding. I've used it in the mode in the past.
https://en.wikipedia.org...nboard_video_compression
I found that vMix did not allow the use of H.264 with this webcam. It returned an error, with a list of allowed resolutions & encoding types as follows:
2304x1296 Unknown (4999998) YUY2
2304x1536 Unknown (4999998) YUY2
640x480 NTSC 30p MJPG
160x90 NTSC 30p MJPG
160x120 NTSC 30p MJPG
176x144 NTSC 30p MJPG
320x180 NTSC 30p MJPG
320x240 NTSC 30p MJPG
352x288 NTSC 30p MJPG
432x240 NTSC 30p MJPG
640x360 NTSC 30p MJPG
800x448 NTSC 30p MJPG
800x600 NTSC 30p MJPG
864x480 NTSC 30p MJPG
960x720 NTSC 30p MJPG
1024x576 NTSC 30p MJPG
1280x720 NTSC 30p MJPG
1600x896 NTSC 30p MJPG
1920x1080 NTSC 30p MJPG
Unspecified error
Thinking this odd, I reached for a C920...and found a similar result. vMix does not allow H.264.
This time the error returned the following:
AddNewInput.The following are supported:
640x480 NTSC 30p RGB
160x90 NTSC 30p RGB
160x120 NTSC 30p RGB
176x144 NTSC 30p RGB
320x180 NTSC 30p RGB
320x240 NTSC 30p RGB
352x288 NTSC 30p RGB
432x240 NTSC 30p RGB
640x360 NTSC 30p RGB
800x448 NTSC 30p RGB
800x600 NTSC 30p RGB
864x480 NTSC 30p RGB
960x720 NTSC 30p RGB
1024x576 NTSC 30p RGB
1280x720 NTSC 30p RGB
1600x896 NTSC 30p RGB
1920x1080 Unknown (2000000) RGB
2304x1296 Unknown (4999998) RGB
2304x1536 Unknown (4999998) RGB
640x480 NTSC 30p I420
160x90 NTSC 30p I420
160x120 NTSC 30p I420
176x144 NTSC 30p I420
320x180 NTSC 30p I420
320x240 NTSC 30p I420
352x288 NTSC 30p I420
432x240 NTSC 30p I420
640x360 NTSC 30p I420
800x448 NTSC 30p I420
800x600 NTSC 30p I420
864x480 NTSC 30p I420
960x720 NTSC 30p I420
1024x576 NTSC 30p I420
1280x720 NTSC 30p I420
1600x896 NTSC 30p I420
1920x1080 Unknown (2000000) I420
2304x1296 Unknown (4999998) I420
2304x1536 Unknown (4999998) I420
Unspecified error
Thinking this now very odd, I grabbed a C930e. Same result.
640x480 NTSC 30p YUY2
160x120 NTSC 30p YUY2
176x144 NTSC 30p YUY2
320x180 NTSC 30p YUY2
320x240 NTSC 30p YUY2
352x288 NTSC 30p YUY2
424x240 NTSC 30p YUY2
480x270 NTSC 30p YUY2
640x360 NTSC 30p YUY2
800x448 NTSC 30p YUY2
800x600 FILM 24p YUY2
848x480 NTSC 30p YUY2
960x540 Unknown (666666) YUY2
1024x576 Unknown (666666) YUY2
1280x720 Unknown (1000000) YUY2
1600x896 Unknown (1333333) YUY2
1920x1080 Unknown (2000000) YUY2
424x240 NTSC 30p MJPG
480x270 NTSC 30p MJPG
848x480 NTSC 30p MJPG
960x540 NTSC 30p MJPG
Unspecified error
It seems that H.264 access to UVC devices is in some manner broken.
kgoodyer
#2 Posted : Friday, August 31, 2018 1:29:02 PM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Are you using the Logitech or Microsoft UVC drivers? I found only the Microsoft UVC drivers worked properly (the irony), but unsure if I was using MJPEG or h.264.
mjgraves
#3 Posted : Tuesday, September 11, 2018 11:44:13 AM(UTC)
mjgraves
Good question. I thought I was using the Microsoft UVC driver. But it's possible that since installing Camera Settings associated with Brio I am using the Logitech driver.
