Stream Start/Stop as a Shortcut
Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
Hey Guys,
just a question if this is a bug on my machine or a usual problem.
I just have made a shortcut for StartStopStreaming. When i click on that button, vMix is not the active program in windows anymore. I need to click in the program again to make it active again so that all my other shortcuts are working.
Same when i just click on stream-button in vmix. The program goes inactive and for sure no shortcuts are working, because its not the active program in windows.
Thanks for reply!
Joined: 3/20/2014(UTC) Views messages in topic : 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 797 time(s) in 591 post(s)
Which key did you set your shortcut on? A keyboard key? Something else ?
The Shortcut is F11 on my regular keyboard.
Okay, even with a complete new setup. When you click on "Stream" in vMix, the vMix Window goes inactive. Thats crazy, but i guess its because in the background ffmpeg is starting up for encoding.
Quote:When you click on "Stream" in vMix, the vMix Window goes inactive No... neither by clicking or using a shortcut... Is vMix window maximized on your screen?
yes, its complety maximized.
Okay, i found something out.
When i use FLME as my encoder the problem don´t happen, when i use ffmpeg the problem occurs.
Very weird! Never seen this before in vMix. You should not lose focus at all...
