Slaver
#1 Posted : Monday, September 10, 2018 6:08:15 AM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hey Guys,
just a question if this is a bug on my machine or a usual problem.
I just have made a shortcut for StartStopStreaming. When i click on that button, vMix is not the active program in windows anymore. I need to click in the program again to make it active again so that all my other shortcuts are working.
Same when i just click on stream-button in vmix. The program goes inactive and for sure no shortcuts are working, because its not the active program in windows.
Thanks for reply!
#2 Posted : Monday, September 10, 2018 10:08:36 AM(UTC)
Forum Rank:: Advanced Member
You have been a member since:: 3/20/2014(UTC)
Which key?
Slaver
#3 Posted : Monday, September 10, 2018 11:23:30 AM(UTC)
Slaver
What do you mean?
#4 Posted : Monday, September 10, 2018 11:29:58 AM(UTC)
Which key did you set your shortcut on? A keyboard key? Something else ?
Slaver
#5 Posted : Monday, September 10, 2018 2:41:32 PM(UTC)
Slaver
The Shortcut is F11 on my regular keyboard.
Slaver
#6 Posted : Tuesday, September 11, 2018 2:22:36 AM(UTC)
Slaver
Okay, even with a complete new setup. When you click on "Stream" in vMix, the vMix Window goes inactive. Thats crazy, but i guess its because in the background ffmpeg is starting up for encoding.
#7 Posted : Tuesday, September 11, 2018 3:17:33 AM(UTC)
No... neither by clicking or using a shortcut...
Is vMix window maximized on your screen?
Slaver
#8 Posted : Tuesday, September 11, 2018 8:05:31 AM(UTC)
Slaver
yes, its complety maximized.
Okay, i found something out.
When i use FLME as my encoder the problem don´t happen, when i use ffmpeg the problem occurs.
#9 Posted : Wednesday, September 12, 2018 4:13:58 AM(UTC)
Very weird! Never seen this before in vMix. You should not lose focus at all...
