Where to change the Default transition etc when clicking on an Input
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everyone, I have an input and when I right click on it, it shows up in the production monitor. That's what I want it to do. I have the input set up as Overlay 4. However, it seems by default it fades up. I want it to CUT to rather than fade up. Also after a few seconds, the input automatically fades out. I want it to stay there until I right click the input again. Is there a setting to make this the default for clicking on an input? Thanks! rowby attached the following image(s):  mouse-click2.jpg (39kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
Have you gone into the Overlay settings section (bottom right of the main window), selected Number 4 (or which ever number you want to work with), changed the Effect, and used 0 to disable the duration?
 1 user thanked TuesdaysLive for this useful post.
Hi Tuesday!
Thanks! I knew there had to be a setting somewhere for that.
Worked perfectly!
...Rowby.
