rowby
#1 Posted : Thursday, September 6, 2018 7:51:52 PM(UTC)
rowby
Hello Everyone,
I have an input and when I right click on it, it shows up in the production monitor. That's what I want it to do. I have the input set up as Overlay 4.
However, it seems by default it fades up. I want it to CUT to rather than fade up.
Also after a few seconds, the input automatically fades out. I want it to stay there until I right click the input again. Is there a setting to make this the default for clicking on an input?
Thanks!
rowby attached the following image(s):
TuesdaysLive
#2 Posted : Thursday, September 6, 2018 8:55:40 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
Have you gone into the Overlay settings section (bottom right of the main window), selected Number 4 (or which ever number you want to work with), changed the Effect, and used 0 to disable the duration?
thanks 1 user thanked TuesdaysLive for this useful post.
rowby on 9/7/2018(UTC)
rowby
#3 Posted : Friday, September 7, 2018 10:25:48 AM(UTC)
rowby
Hi Tuesday!
Thanks! I knew there had to be a setting somewhere for that.
Worked perfectly!
...Rowby.
