Audio delay on videos played in vMix
I have a odd problem with our vMix setup. We've figured out our audio delay for our microphones, and we changed the delay in the "Audio" section of Settings.
But if we during a stream cut to a preproduced video, the audio on that video suddenly is way out of sync. And there doesn't seem to be a option to individually change the audio delay for that specific video.
Is there a way around this issue? And is there a good way to test for audio delay (other then clapping in front of a camera?)
@ MikkelWinther
Methinks you have adjusted the wrong settings... Each Audio Input in vMix can have it's Audio delay set individually: vMix Audio Mixer ===> cog wheel of Input ===> Audio delay Slider By the sound of it, you have adjusted the MASTER Audio Settings in vMix: Settings ===> Audio ===> Default Input Audio Delay This will affect all Inputs in vMix. I would suggest setting this back to 0 and adjusting your Microphone delay in the vMix Audio Mixer instead.
IceStream wrote:@ MikkelWinther
Ice Thanks, will look into that. Will those settings also ripple down to the recorded version of a show, or is there a seperate setting for the recorded version?
