Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I have written a blend dll and i would like to call a couple of vMix function when things happen.
Essentially i want to open TCP port 8099 and make a function call in blend i guess...
Could smebody share the code i migtht need with the includes
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Need to add web browser in code and make it not visible then send api command. Visual Basic code example:Add Web browser<WebView x:Name="WebBrowser" HorizontalAlignment="Stretch" Height="100" Margin="286,868,0,0" VerticalAlignment="Stretch" Width="100" Visibility="Collapsed" d:IsHidden="True" /> Send API command via HTTP (vMix API command is in RED)Uri is the HTTP command you want to send. WebBrowser.Navigate(New Uri(" http://127.0.0.1:8099/API/?Function=SetText&SelectedIndex=1&Value=Camera%20Preset&Input=1")) smudge1977 wrote:I have written a blend dll and i would like to call a couple of vMix function when things happen.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
or directly send httprequest from within your code, no need to open a webbrowser
Here is what is used (not using http as plain text on port 8099 will be faster) As i say this is running in the compiled DLL from the xaml for a title input. This makes the code a nightmare to debug! Would even be nice to know where Console.WriteLine outputs stuff....??? This as you can tell was a kind of quick copy paste from a stackexchange page! Need to do the read before the write to get the data that is 'waiting' after you connect to vMix! Function vMixCall(command As String) Dim client = New TcpClient() Try client.Connect("127.0.0.1", 8099) Dim networkStream As NetworkStream = client.GetStream() ' Read the NetworkStream into a byte buffer. 'This reads the welcome header fro vMix Dim bytes(client.ReceiveBufferSize) As Byte networkStream.Read(bytes, 0, CInt(client.ReceiveBufferSize)) ' Output the data received from the host to the console. Dim returndata As String = Encoding.ASCII.GetString(bytes) Console.WriteLine(("Host returned: " + returndata)) Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(command + vbCrLf) networkStream.Write(sendBytes, 0, sendBytes.Length) Catch ex As Exception Finally client.Close() End Try 'FUNCTION OverlayInput1 Input=2 'PowerRed.Text = "2" End Function File Attachment(s):  UserControl1.xaml (6kb) downloaded 80 time(s). UserControl1.xaml - Copy.vb.txt (6kb) downloaded 77 time(s).You cannot view/download attachments. Try to login or register.
Joined: 2/2/2018(UTC) Posts: 13 Location: Foz do Iguaçu
