smudge1977
#1 Posted : Sunday, September 2, 2018 4:48:24 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I have written a blend dll and i would like to call a couple of vMix function when things happen.
Essentially i want to open TCP port 8099 and make a function call in blend i guess...
Could smebody share the code i migtht need with the includes
desmar
#2 Posted : Monday, September 3, 2018 3:28:44 AM(UTC)
desmar
Canada
Need to add web browser in code and make it not visible then send api command.
Visual Basic code example:
Add Web browser
<WebView x:Name="WebBrowser" HorizontalAlignment="Stretch" Height="100" Margin="286,868,0,0" VerticalAlignment="Stretch" Width="100" Visibility="Collapsed" d:IsHidden="True" />
Send API command via HTTP (vMix API command is in RED)
Uri is the HTTP command you want to send.
WebBrowser.Navigate(New Uri("http://127.0.0.1:8099/API/?Function=SetText&SelectedIndex=1&Value=Camera%20Preset&Input=1"))
#3 Posted : Monday, September 3, 2018 4:58:44 AM(UTC)
or directly send httprequest from within your code, no need to open a webbrowser
smudge1977
#4 Posted : Wednesday, September 5, 2018 1:43:45 PM(UTC)
smudge1977
Here is what is used (not using http as plain text on port 8099 will be faster)
As i say this is running in the compiled DLL from the xaml for a title input. This makes the code a nightmare to debug!
Would even be nice to know where Console.WriteLine outputs stuff....???
This as you can tell was a kind of quick copy paste from a stackexchange page! Need to do the read before the write to get the data that is 'waiting' after you connect to vMix!
Function vMixCall(command As String)
Dim client = New TcpClient()
Try
client.Connect("127.0.0.1", 8099)
Dim networkStream As NetworkStream = client.GetStream()
' Read the NetworkStream into a byte buffer.
'This reads the welcome header fro vMix
Dim bytes(client.ReceiveBufferSize) As Byte
networkStream.Read(bytes, 0, CInt(client.ReceiveBufferSize))
' Output the data received from the host to the console.
Dim returndata As String = Encoding.ASCII.GetString(bytes)
Console.WriteLine(("Host returned: " + returndata))
Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(command + vbCrLf)
networkStream.Write(sendBytes, 0, sendBytes.Length)
Catch ex As Exception
Finally
client.Close()
End Try
'FUNCTION OverlayInput1 Input=2
'PowerRed.Text = "2"
End Function
File Attachment(s):
UserControl1.xaml (6kb) downloaded 79 time(s).
UserControl1.xaml - Copy.vb.txt (6kb) downloaded 76 time(s).
claudeir
#5 Posted : Friday, September 7, 2018 2:06:38 PM(UTC)
claudeir
how can I user that?
