STADIORADIO
#1 Posted : Thursday, August 30, 2018 6:29:39 AM(UTC)
STADIORADIO
Good morning I have difficulty to perform simultaneous stream on facebook and youtube, is there any limitation?
Grazie!
STADIORADIO attached the following image(s):
Barney Box Lane
#2 Posted : Thursday, August 30, 2018 6:54:44 AM(UTC)
Barney Box Lane
use a custom rtmp stream for your first stream to Facebook, then stream now to YouTube in your second stream... Facebook won't let you stream to another place so that's the work around
thanks 1 user thanked Barney Box Lane for this useful post.
STADIORADIO on 8/30/2018(UTC)
STADIORADIO
#3 Posted : Thursday, August 30, 2018 1:45:55 PM(UTC)
STADIORADIO
Porca misery. This is a big mess problem. I hope you can solve it in any way, however, as you suggested it seems to work, even if the procedure to be done is very long. Thank you very much
jpratchett
#4 Posted : Saturday, September 1, 2018 1:00:51 PM(UTC)
jpratchett
Try Restream.io
I use them now for all my streaming. point to them and then you can go out to anywhere. also saves you bandwidth and processing as only sending one stream out of vmix.
Jon
thanks 2 users thanked jpratchett for this useful post.
Brian E. Conklin on 9/2/2018(UTC), STADIORADIO on 9/3/2018(UTC)
guztavo
#5 Posted : Saturday, September 1, 2018 8:31:18 PM(UTC)
guztavo
As Jon, i also use restream. Saves bandwidth and processing.
Highly recommended.
Regards.
jpratchett wrote:
Try Restream.io
Jon
thanks 1 user thanked guztavo for this useful post.
#6 Posted : Sunday, September 2, 2018 1:14:54 AM(UTC)
@ STADIORADIO
Unfortunately, such is the reality with Facebook...
https://www.vmix.com/kno...en-streaming-to-facebook
STADIORADIO
#7 Posted : Sunday, September 2, 2018 10:47:13 AM(UTC)
STADIORADIO
Highly recommended.
Regards.
jpratchett wrote:
Try Restream.io
Jon
but also with the free version?
STADIORADIO
#8 Posted : Sunday, September 2, 2018 1:03:00 PM(UTC)
STADIORADIO
In any case, I was noticing a strange thing. I can send the two streams at the same time, and it seems that everything works correctly, I do not see any buffer signaling, but the band used does not reach the one set, both for facebook and for youtube
STADIORADIO
#9 Posted : Sunday, September 2, 2018 1:34:49 PM(UTC)
STADIORADIO
clearly I have many mega uploads, 50 to be precise
