Streaming Simultaneously to Facebook and YouTube difficulty
Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Good morning I have difficulty to perform simultaneous stream on facebook and youtube, is there any limitation? Grazie! STADIORADIO attached the following image(s):  test.png (28kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
use a custom rtmp stream for your first stream to Facebook, then stream now to YouTube in your second stream... Facebook won't let you stream to another place so that's the work around
 1 user thanked Barney Box Lane for this useful post.
Porca misery. This is a big mess problem. I hope you can solve it in any way, however, as you suggested it seems to work, even if the procedure to be done is very long. Thank you very much
Joined: 8/26/2017(UTC) Posts: 11  Location: UK Was thanked: 4 time(s) in 3 post(s)
Try Restream.io
I use them now for all my streaming. point to them and then you can go out to anywhere. also saves you bandwidth and processing as only sending one stream out of vmix.
Jon
 2 users thanked jpratchett for this useful post.
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
As Jon, i also use restream. Saves bandwidth and processing. Highly recommended. Regards. jpratchett wrote:Try Restream.io
Jon
 1 user thanked guztavo for this useful post.
guztavo wrote:As Jon, i also use restream. Saves bandwidth and processing. Highly recommended. Regards. jpratchett wrote:Try Restream.io
Jon but also with the free version?
In any case, I was noticing a strange thing. I can send the two streams at the same time, and it seems that everything works correctly, I do not see any buffer signaling, but the band used does not reach the one set, both for facebook and for youtube STADIORADIO attached the following image(s):  banda.jpg (397kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
clearly I have many mega uploads, 50 to be precise
