Joined: 11/2/2017(UTC) Posts: 14  Location: Portland, OR Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Does anyone have experience working in vMix with the Lynx or RME internal PCIe cards?
I'm looking for a solution to replace my Decklink card as the main audio input.
Thoughts?
Thanks,
Derek
 1 user thanked twidget for this useful post.
While I can't speak to those cards, many vMix users use USB audio interfaces from Behringer, Focusrite and the like.
Also, some people use DANTE to ingest audio over IP.
Those are good devices. We use Focusrite on a few of our media servers.
These need to be internal since these systems will be part of a rack mount system for traveling from event to event.
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
 1 user thanked PFBM for this useful post.
Thanks. I wanted to make sure that the interface was reliable through vMix before purchasing.
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
twidget wrote:Thanks. I wanted to make sure that the interface was reliable through vMix before purchasing. Which card did you end up pursuing? And do you need analog in primarily? I'm looking for a PCI-express card with XLR or at least 6.35mm jack on it. Do you expect that you need to delay the audio manually in vMix for lipsync?
Going to purchase the E22 from Lynx. Will update this thread when it comes in and I have tested it.
After looking at the Maya44, I'm going to order that one first and test with it.
I like the 1/4" TRS direct input over ANOTHER breakout cable.
twidget wrote:After looking at the Maya44, I'm going to order that one first and test with it.
I like the 1/4" TRS direct input over ANOTHER breakout cable. Exactly! Let me know how well it works. Thanks.
