twidget
#1 Posted : Tuesday, August 21, 2018 8:08:01 PM(UTC)
twidget
Does anyone have experience working in vMix with the Lynx or RME internal PCIe cards?
I'm looking for a solution to replace my Decklink card as the main audio input.
Thoughts?
Thanks,
Derek
thanks 1 user thanked twidget for this useful post.
PFBM on 8/25/2018(UTC)
mjgraves
#2 Posted : Thursday, August 23, 2018 10:40:44 AM(UTC)
mjgraves
While I can't speak to those cards, many vMix users use USB audio interfaces from Behringer, Focusrite and the like.
Also, some people use DANTE to ingest audio over IP.
twidget
#3 Posted : Friday, August 24, 2018 12:28:48 AM(UTC)
twidget
Those are good devices. We use Focusrite on a few of our media servers.
These need to be internal since these systems will be part of a rack mount system for traveling from event to event.
PFBM
#4 Posted : Saturday, August 25, 2018 1:56:33 PM(UTC)
PFBM
Was thanked: 35 time(s) in 30 post(s)
HI !!
yes i use RME. its very good and stable !!
but.... not cheap...
also lynx is another great pro reference.
pcie is always better than usb or firewire....
yes some usb drivers are very stable like RME for example
Dante is a very good option if you need it...
always use hardware dante interface, ( if you can ), not the simple dante virtual driver, due to higher latency.
http://www.rme-audio.de/...ducts/digiface_dante.php
https://pro.focusrite.co...overip/item/rednet-pcier
Kind Regards,
PFBM
thanks 1 user thanked PFBM for this useful post.
twidget on 8/25/2018(UTC)
twidget
#5 Posted : Saturday, August 25, 2018 2:16:39 PM(UTC)
twidget
Thanks. I wanted to make sure that the interface was reliable through vMix before purchasing.
niemi
#6 Posted : Tuesday, August 28, 2018 11:25:57 AM(UTC)
niemi
Was thanked: 18 time(s) in 15 post(s)
Which card did you end up pursuing? And do you need analog in primarily?
I'm looking for a PCI-express card with XLR or at least 6.35mm jack on it.
Do you expect that you need to delay the audio manually in vMix for lipsync?
twidget
#7 Posted : Tuesday, August 28, 2018 11:45:36 AM(UTC)
twidget
Going to purchase the E22 from Lynx. Will update this thread when it comes in and I have tested it.
niemi
#8 Posted : Tuesday, August 28, 2018 11:58:14 AM(UTC)
niemi
Thanks twidget. Please do.
Which card with onboard 6.35mm jacks (without having to bring break-out cables) would you choose, if any?
I have been looking at the ESI MAYA44 eX:
https://www.thomann.de/g...si_maya44_ex_b_stock.htm
twidget
#9 Posted : Wednesday, August 29, 2018 8:23:01 PM(UTC)
twidget
After looking at the Maya44, I'm going to order that one first and test with it.
I like the 1/4" TRS direct input over ANOTHER breakout cable.
niemi
#10 Posted : Saturday, September 22, 2018 3:06:49 PM(UTC)
niemi
Exactly! Let me know how well it works.
Thanks.
Guest (4)
