pc i3-6100 -3.70ghz ram 16 gb ssd 120 gb grapich card Gt 1050 ti 4 gb Declink Blackmagic sdi win 7 professional 64 bit service pack 1 no antivirus software: only vmix Hi, I'm doing a playlist with vmix of only video clips of the total duration of about 8 hours in loop, without external inputs and with only a fixed title in overlay. The problem is that after about 3 hours vmix starts to go jerky and to solve the problem I have to restart it, I also changed the clips but with no result, can someone help me? thanks I attach the statistical photos and render external render dropped after about 3 is very high (about 60000) File Attachment(s):  WhatsApp Image 2018-08-15 at 09.22.14.bmp (2,907kb) downloaded 27 time(s). WhatsApp Image 2018-08-15 at 09.22.36.bmp (2,907kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 321 times Was thanked: 263 time(s) in 233 post(s)
The screen shot appears to shot lots of dropped frame, so the BMD card or driver appears to be the issue.
thanks for the answer the drivers have changed them but continue the error, do you think the card is broken? can it be a slot problem? but unfortunately I have no other slots to try. thank you
Thanks mjgraves, solved, it was the declink that gave problems, I changed everything now ok. Thank you
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
+1 I would buy vmix jerky, but will settle for mousepad
