op music
#1 Posted : Thursday, August 16, 2018 3:28:12 AM(UTC)
op music
pc i3-6100 -3.70ghz
ram 16 gb
ssd 120 gb
grapich card Gt 1050 ti 4 gb
Declink Blackmagic sdi
win 7 professional 64 bit service pack 1
no antivirus
software: only vmix
Hi, I'm doing a playlist with vmix of only video clips of the total duration of about 8 hours in loop, without external inputs and with only a fixed title in overlay.
The problem is that after about 3 hours vmix starts to go jerky and to solve the problem I have to restart it, I also changed the clips but with no result, can someone help me? thanks I attach the statistical photos and render
external render dropped after about 3 is very high (about 60000)
File Attachment(s):
WhatsApp Image 2018-08-15 at 09.22.14.bmp (2,907kb) downloaded 27 time(s).
WhatsApp Image 2018-08-15 at 09.22.36.bmp (2,907kb) downloaded 10 time(s).
mjgraves
#2 Posted : Thursday, August 16, 2018 6:05:00 PM(UTC)
mjgraves
The screen shot appears to shot lots of dropped frame, so the BMD card or driver appears to be the issue.
op music on 8/17/2018(UTC)
op music
#3 Posted : Friday, August 17, 2018 3:43:47 AM(UTC)
op music
thanks for the answer the drivers have changed them but continue the error, do you think the card is broken? can it be a slot problem? but unfortunately I have no other slots to try. thank you
op music
#4 Posted : Saturday, August 18, 2018 4:58:46 AM(UTC)
op music
Thanks mjgraves, solved, it was the declink that gave problems, I changed everything now ok. Thank you
Barney Box Lane
#5 Posted : Sunday, August 19, 2018 7:38:01 AM(UTC)
Barney Box Lane
+1 I would buy vmix jerky, but will settle for mousepad
