Run shortcut at vMix startup
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
Is there in the meantime a simple solution to execute a shortcut when vMix starts?
I want to select a specific input category at vMix startup.
The present input category is not saved in a preset. vMix will always start with the 'all inputs' category.
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Autohotkey ?
Run, vMix.exe or preset sleep,appropriate timedelay Send {your shortcut key} return
edit: or can add the WinWait command to it instead of sleep ?
I am using a Java script right now, that is also working, but sometimes vMix starts up in 5 seconds and sometimes it takes 30 seconds. So I can send the shortcut not before app. 40 seconds. It's just a little bit ignoring that vMix still has no trigger on startup option. There are a lot of feature requests for 'autostart recording, streaming etc.' but not enough apparently. So I will add one again: So folks, vote for it :)
