Ronald555
#1 Posted : Tuesday, August 14, 2018 6:38:49 AM(UTC)
Ronald555
Is there in the meantime a simple solution to execute a shortcut when vMix starts?
I want to select a specific input category at vMix startup.
elvis55
#2 Posted : Tuesday, August 14, 2018 6:59:30 AM(UTC)
elvis55
Switzerland
Hallo,
Presets ??
Gruss
Ronald555
#3 Posted : Tuesday, August 14, 2018 7:06:28 AM(UTC)
Ronald555
The present input category is not saved in a preset.
vMix will always start with the 'all inputs' category.
#4 Posted : Tuesday, August 14, 2018 7:20:12 AM(UTC)
Autohotkey ?
Run, vMix.exe or preset
sleep,appropriate timedelay
Send {your shortcut key}
return
edit: or can add the WinWait command to it instead of sleep ?
Ronald555
#5 Posted : Tuesday, August 14, 2018 7:38:20 AM(UTC)
Ronald555
I am using a Java script right now, that is also working, but sometimes vMix starts up in 5 seconds and sometimes it takes 30 seconds.
So I can send the shortcut not before app. 40 seconds.
It's just a little bit ignoring that vMix still has no trigger on startup option. There are a lot of feature requests for 'autostart recording, streaming etc.' but not enough apparently.
So I will add one again:
So folks, vote for it :)
Guest (4)
