GPSIS
#1 Posted : Thursday, August 9, 2018 1:58:31 PM(UTC)
GPSIS
Hello all,
I am looking for virtual Green Screen software I can use with vMIX and my Logitech C922 camera.
The ChromaCam software recommended by Logitech does not work with vMIX.
Looking for something stable & reliable...anyone got ideas?
FYI...looking for answers from those that have actually used the product, not those that "heard it through the grapevine".
Regards!
richardgatarski
#2 Posted : Thursday, August 9, 2018 3:44:00 PM(UTC)
richardgatarski
Hi and welcome to the Forum. Can you explain what you need to do, that cannot be done with vMix? (e.g. https://www.vmix.com/kno...hroma-key-setup-in-vmix)
mjgraves
#3 Posted : Thursday, August 9, 2018 6:38:00 PM(UTC)
mjgraves
Chromacam was intended to let gamers add themselves over top of their game play, typically working with OBS or similar. It attempts to fake a composite by trying to discern foreground from background without a proper green screen.
This presents three problems:
(1) Sometimes it just doesn't work at all.
(2) Even when it kinda works, it doesn't work very well. YouTube abounds with examples of this.
(3) It's a CPU hog.
This example I just made is typical.
You'll get way better results by just getting the proper green screen and some lights.
El Gato makes a nice pop-up green screen just for the purpose. https://amzn.to/2OQFSyS
You can get a background, stands and a light kit for around $120. https://amzn.to/2Md2POf
GPSIS
#4 Posted : Friday, August 10, 2018 11:09:12 AM(UTC)
GPSIS
Hello richardgatarski
I just want to add a simple virtual background to my videos...nothing high end; very basic.
I'm new to vMIX and was not aware it had the feature built in.
I'll look into the link you provided and get back to you.
Regards!
GPSIS
#5 Posted : Friday, August 10, 2018 11:13:36 AM(UTC)
GPSIS
(3) It's a CPU hog.
Hello mjgraves
I'm an occasional video creator and was trying to avoid putting out mor that 30-40 bucks for a solution, but I'll definitely look into your recommendations...and thanks for the screenshot and the ensight to the limitations of the software.
Regards!
mjgraves
#6 Posted : Friday, August 10, 2018 6:49:29 PM(UTC)
mjgraves
A green paper or plastic table cloth & some clothes pins. A couple of dirt cheap lights.
Check out Tom Sinclair's studio tour on YouTube. He gets it done well and inexpensively.
GPSIS
#7 Posted : Tuesday, August 14, 2018 10:34:00 AM(UTC)
GPSIS
Got a chance to play with the option you suggested this past weekend.
I THINK I followed the instructions but did not get the results I was looking to achieve.
I got the CAPTURE view screen up and configured, and the IMAGE view screen up and configured, but could not get them to "merger" together.
Do I actually need a green background to make this happen?
If so I am looking for a software solution rather than a physical hardware [green cloth background] solution.
My apologies for not making that clear.
Regards!
mjgraves
#8 Posted : Tuesday, August 14, 2018 11:19:06 AM(UTC)
mjgraves
Perhaps try https://www.tridef.com/products/smartcam
I doubt it will work with vMix, but they appear to have versions for XSplit and other game-centric apps.
TuesdaysLive
#9 Posted : Tuesday, August 14, 2018 12:23:26 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
Interestingly enough, it does appear to be functional (I hesitate to say 'work') with vMix. However, the results are similar to those from Chromacam, as seen in the example above.
