66 Pages«<2728293031>»
Snooker Loopy
#561 Posted : Sunday, August 5, 2018 11:50:03 AM(UTC)
Snooker Loopy
elgarf wrote:
Sooo, I've made some changes:
1) LIVE switch, wich affects on all text-based widgets like Text Field, Score, Timer, etc. If it switched off, all changes will be visible only in UTC.
2) Path select button in Text Field widget.
3) A little more colors (and you can add your own by editing Colours.xml file). Caption text color is black or white, based on caption background brightness.
4) "About" window, where you can push button & go to this thread =)
First Post
@elgarf - you read my mind with the changes made - I've used all four of them already and had a crash course in how to modify the Colours.xml file.
I had a slight problem whilst trying to make a donation (default browser is IE11 on the VMix machine so maybe that was why). However, I have managed to make the donation by downloading on a laptop with Chrome so a token of my appreciation is on it's way to you.
Since I've no idea what the going rate is for what you've achieved, I won't be offended if you tell me that the donation is a little on the low side and am happy to make up any shortfall - just let me know :-)
brownm
#562 Posted : Tuesday, August 7, 2018 6:36:24 PM(UTC)
brownm
First Post
AWESOME!!!!
Would there be a way to script an "Update" button? Basically I want to idiot proof it for my operator so when he hits "Update" Live mode switches on for a second and then right back off so he can make changes.
elgarf
#563 Posted : Thursday, August 9, 2018 1:50:57 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
At now you can script Update button, but can't script LIVE switch. I made an update with new command, which will trigger LIVE switch on/off.
elgarf
#564 Posted : Saturday, August 11, 2018 1:49:48 AM(UTC)
elgarf
Russian Federation
Updated UTC with LIVE toggle commands, so you can switch LIVE mode by script.
NDI monitor now have clickable multiview mode:
1) Map inputs into title mapping of external data widget
2) Select multiview layout
3) Now you can switch inputs by clicking into multiview
First post
chococrispis35
#565 Posted : Thursday, August 16, 2018 5:20:43 PM(UTC)
chococrispis35
It´s my UTC project with Vmix for Football Soccer, i created graphics and animation en Visual Blend and Excel
chezter
#566 Posted : Sunday, August 19, 2018 4:32:10 PM(UTC)
chezter
I like the last update, solved my problem with the NDI.
Thank you.
Siroki
#567 Posted : Monday, August 20, 2018 4:53:52 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Hi
You did a nice job. Nice looking graphics.
Best regards
Jboze
#568 Posted : Wednesday, August 22, 2018 3:40:10 PM(UTC)
Jboze
How did you get the roster to read the way it did?
Snooker Loopy
#569 Posted : Friday, August 24, 2018 11:55:37 AM(UTC)
Snooker Loopy
Hi again oh knowledgeable peeps :-)
I set up a test with UTC to control and monitor a scoreboard and was very happy with the result. Since then I have purchased vMix HD and now I cannot monitor my scoreboard through UTC. So far, I have checked all the paths, updated state (several times) and re-created the controls in a new vmc file, all to no avail.
UTC is latest version (10-8-2018) and vMix is v21.0.0.45 (x64)
Is it possible that I have inadvertently changed something somewhere or is UTC not compatible with vMix HD?
Appreciate any advice/help anyone can offer.
elgarf
#570 Posted : Friday, August 24, 2018 1:48:13 PM(UTC)
elgarf
Russian Federation
@Snooker Loopy, is NDI monitor not working or title mapping? Does widgets have red border?
Snooker Loopy
#571 Posted : Friday, August 24, 2018 4:53:39 PM(UTC)
Snooker Loopy
Hi elgarf, thanks for responding
Everything appears normal, no red widgets, online button is green. When using the dropdown in the external data widget it only gives option of 'Output 1', nothing else.
I tried setting 'Fullscreen' to input 3 (which is the scoreboard) but that doesn't appear in the list either, although I'm not sure it should since it's not sent out via NDI to my knowledge.
elgarf
#572 Posted : Monday, August 27, 2018 8:14:01 AM(UTC)
elgarf
Russian Federation
@Snooker Loopy, do you switch NDI output ON into Outputs/NDI settings?
Snooker Loopy
#573 Posted : Tuesday, August 28, 2018 12:36:32 PM(UTC)
Snooker Loopy
@elgarf, I've been playing around with the NDI settings since my last post and not seen any difference. I can only get to monitor Output 1 through UTC (all other control widgets work great).
However, having done a little more research, I think the issue may be that when I set up the test, vMix Trial was installed. Since then, as mentioned in a previous post, I have purchased vMix HD which only has one output. Could that be the reason why?
elgarf
#574 Posted : Tuesday, August 28, 2018 12:44:57 PM(UTC)
elgarf
Russian Federation
@Snooker Loopy, yep, this can be an issue. You can set up more outputs in other editions.
elgarf attached the following image(s):
2018-08-27 (3).png (30kb) downloaded 43 time(s).
#575 Posted : Tuesday, August 28, 2018 12:45:36 PM(UTC)
Make sure to set (and activate) vMix NDI outputs correctly, especially the Out2 which should be set with your title.
Check https://www.vmix.com/help21/SettingsOutputs.html
Guillaume
Snooker Loopy
#576 Posted : Tuesday, August 28, 2018 2:59:46 PM(UTC)
Snooker Loopy
@elgarf, is there any way round this using UTC or another method that you may know of?
I have 4 laptops each with their own copy of vMix - 1 x vMix HD and 3 x vMix Basic HD. In order to get the additional output on each would entail upgrading all 4 copies to vMix 4K with an associated cost of $2,270 (approx. £1,760) which is way out of my personal budget.
@DWAM, Turns out that NDI is probably not the issue but many thanks for your input.
elgarf
#577 Posted : Wednesday, August 29, 2018 12:51:27 AM(UTC)
elgarf
Russian Federation
@Snooker Loopy, you just need to see your scoreboard?
As a workaround you can out MultiViewer (2x2) through NDI. Not sure if Basic/Basic HD can do this.
chococrispis35
#578 Posted : Wednesday, August 29, 2018 1:02:57 PM(UTC)
chococrispis35
its my Baseball project UTC update Julio 2018, excel data input, graphics created with visual studio
thanks 1 user thanked chococrispis35 for this useful post.
timbrian on 12/19/2018(UTC)
Snooker Loopy
#579 Posted : Wednesday, August 29, 2018 5:10:35 PM(UTC)
Snooker Loopy
@elgarf
Yes, I only need to see the scoreboard.
I'm not sure how to achieve sending out Multiviewer (2x2) through NDI though. Could you explain a little what I need to be looking for please?
Jboze
#580 Posted : Thursday, August 30, 2018 7:42:03 PM(UTC)
Jboze
This is an awesome setup! I have so many questions! Mainly, is the data just reading from a standard Excel sheet, or is it an XML? And how did you set up the button to go to the next player in the lineup for the lower third ID?
But seriously, both this and your Soccer/Football graphic setups are incredible!
Regards!
Guest (15)
