elgarf wrote:Sooo, I've made some changes: 1) LIVE switch, wich affects on all text-based widgets like Text Field, Score, Timer, etc. If it switched off, all changes will be visible only in UTC. 2) Path select button in Text Field widget. 3) A little more colors (and you can add your own by editing Colours.xml file). Caption text color is black or white, based on caption background brightness. 4) "About" window, where you can push button & go to this thread =) First Post @elgarf - you read my mind with the changes made - I've used all four of them already and had a crash course in how to modify the Colours.xml file. I had a slight problem whilst trying to make a donation (default browser is IE11 on the VMix machine so maybe that was why). However, I have managed to make the donation by downloading on a laptop with Chrome so a token of my appreciation is on it's way to you. Since I've no idea what the going rate is for what you've achieved, I won't be offended if you tell me that the donation is a little on the low side and am happy to make up any shortfall - just let me know :-)
elgarf wrote:Sooo, I've made some changes: 1) LIVE switch, wich affects on all text-based widgets like Text Field, Score, Timer, etc. If it switched off, all changes will be visible only in UTC. 2) Path select button in Text Field widget. 3) A little more colors (and you can add your own by editing Colours.xml file). Caption text color is black or white, based on caption background brightness. 4) "About" window, where you can push button & go to this thread =) First Post AWESOME!!!! Would there be a way to script an "Update" button? Basically I want to idiot proof it for my operator so when he hits "Update" Live mode switches on for a second and then right back off so he can make changes.
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
At now you can script Update button, but can't script LIVE switch. I made an update with new command, which will trigger LIVE switch on/off.
Updated UTC with LIVE toggle commands, so you can switch LIVE mode by script. NDI monitor now have clickable multiview mode: 1) Map inputs into title mapping of external data widget 2) Select multiview layout 3) Now you can switch inputs by clicking into multiview First post
Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
It´s my UTC project with Vmix for Football Soccer, i created graphics and animation en Visual Blend and Excel
I like the last update, solved my problem with the NDI. Thank you.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
chococrispis35 wrote:It´s my UTC project with Vmix for Football Soccer, i created graphics and animation en Visual Blend and Excel Hi You did a nice job. Nice looking graphics. Best regards
chococrispis35 wrote:It´s my UTC project with Vmix for Football Soccer, i created graphics and animation en Visual Blend and Excel How did you get the roster to read the way it did?
Hi again oh knowledgeable peeps :-)
I set up a test with UTC to control and monitor a scoreboard and was very happy with the result. Since then I have purchased vMix HD and now I cannot monitor my scoreboard through UTC. So far, I have checked all the paths, updated state (several times) and re-created the controls in a new vmc file, all to no avail.
UTC is latest version (10-8-2018) and vMix is v21.0.0.45 (x64)
Is it possible that I have inadvertently changed something somewhere or is UTC not compatible with vMix HD?
Appreciate any advice/help anyone can offer.
@Snooker Loopy, is NDI monitor not working or title mapping? Does widgets have red border?
Hi elgarf, thanks for responding
Everything appears normal, no red widgets, online button is green. When using the dropdown in the external data widget it only gives option of 'Output 1', nothing else.
I tried setting 'Fullscreen' to input 3 (which is the scoreboard) but that doesn't appear in the list either, although I'm not sure it should since it's not sent out via NDI to my knowledge.
@Snooker Loopy, do you switch NDI output ON into Outputs/NDI settings?
@elgarf, I've been playing around with the NDI settings since my last post and not seen any difference. I can only get to monitor Output 1 through UTC (all other control widgets work great).
However, having done a little more research, I think the issue may be that when I set up the test, vMix Trial was installed. Since then, as mentioned in a previous post, I have purchased vMix HD which only has one output. Could that be the reason why?
@Snooker Loopy, yep, this can be an issue. You can set up more outputs in other editions. elgarf attached the following image(s):  2018-08-27 (3).png (30kb) downloaded 43 time(s).You cannot view/download attachments. Try to login or register.
@elgarf, is there any way round this using UTC or another method that you may know of?
I have 4 laptops each with their own copy of vMix - 1 x vMix HD and 3 x vMix Basic HD. In order to get the additional output on each would entail upgrading all 4 copies to vMix 4K with an associated cost of $2,270 (approx. £1,760) which is way out of my personal budget.
@DWAM, Turns out that NDI is probably not the issue but many thanks for your input.
@Snooker Loopy, you just need to see your scoreboard?
As a workaround you can out MultiViewer (2x2) through NDI. Not sure if Basic/Basic HD can do this.
its my Baseball project UTC update Julio 2018, excel data input, graphics created with visual studio
 1 user thanked chococrispis35 for this useful post.
@elgarf
Yes, I only need to see the scoreboard. I'm not sure how to achieve sending out Multiviewer (2x2) through NDI though. Could you explain a little what I need to be looking for please?
chococrispis35 wrote:its my Baseball project UTC update Julio 2018, excel data input, graphics created with visual studio This is an awesome setup! I have so many questions! Mainly, is the data just reading from a standard Excel sheet, or is it an XML? And how did you set up the button to go to the next player in the lineup for the lower third ID? But seriously, both this and your Soccer/Football graphic setups are incredible! Regards!
