spencerm24
#1 Posted : Monday, July 30, 2018 12:59:49 PM(UTC)
spencerm24
I know vMix can't schedule events based on time of day, is there some other way I can execute a shortcut at a specific time of day? I need a countdown to start at 7:15pm, so the show runs at 7:30, but am not always present at 7:15 to hit the button, so if I can somehow automate it, that would be perfect. Is there a way? third party?
Barney Box Lane
#2 Posted : Tuesday, July 31, 2018 5:20:42 AM(UTC)
Barney Box Lane
stick a radio alarm clock next to the computer, run the headphone out into the computer, trigger start of the show when noise level is over -6db on the input )
pm
#3 Posted : Tuesday, July 31, 2018 6:55:17 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
One idea could be to start a script by Windows task scheduler. In the script make a http vMix web scripting call with the function "KeyPress"
Patrick
thanks 1 user thanked pm for this useful post.
spencerm24 on 7/31/2018(UTC)
stevespaw
#4 Posted : Tuesday, July 31, 2018 9:01:47 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
We use this,
vTask - it works very well.
http://vfxblend.com/tutorials/
Steve
madness
#5 Posted : Tuesday, July 31, 2018 12:21:56 PM(UTC)
madness
Autohotkey can send a webAPI command using a time trigger.
Code:
#SingleInstance Force
#Persistent
	; Poll the time every second for precise timing....
	SetTimer, CheckTheTime, 1000 ; 1000 is milliseconds
Return
CheckTheTime: ;{
	TheTime := A_Hour . A_Min . A_Sec ; Create the time format to compare with
	If (TheTime == 111400)	; Compare "The Time" with the trigger time of your chosing
	{ 	; Web API command goes here
		msgbox Time Triggered	; Sample trigger command replaced by Web API command.
Return
spencerm24
#6 Posted : Tuesday, July 31, 2018 2:31:58 PM(UTC)
spencerm24
Patrick
This seems to be the simplest and easiest way to do this. Thanks!!
Vuurmannetje
#7 Posted : Tuesday, July 31, 2018 6:15:23 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
Another option is to get a midi based clock, or if you have Qlab can trigger on time.
Get rtpMidi to transmit it to Vmix and set.
kjones9999
#8 Posted : Saturday, August 4, 2018 5:34:31 PM(UTC)
kjones9999
I used AHK to make this program -- just put in the shortcut -
https://forums.vmix.com/...aspx?g=posts&t=14302
thanks 1 user thanked kjones9999 for this useful post.
WayneMHK on 11/17/2020(UTC)
