Automatically run a shortcut at a set time
I know vMix can't schedule events based on time of day, is there some other way I can execute a shortcut at a specific time of day? I need a countdown to start at 7:15pm, so the show runs at 7:30, but am not always present at 7:15 to hit the button, so if I can somehow automate it, that would be perfect. Is there a way? third party?
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
stick a radio alarm clock next to the computer, run the headphone out into the computer, trigger start of the show when noise level is over -6db on the input )
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
One idea could be to start a script by Windows task scheduler. In the script make a http vMix web scripting call with the function "KeyPress"
Regards, Patrick
 1 user thanked pm for this useful post.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Autohotkey can send a webAPI command using a time trigger. Code:#SingleInstance Force
#Persistent
; Poll the time every second for precise timing....
SetTimer, CheckTheTime, 1000 ; 1000 is milliseconds
Return
CheckTheTime: ;{
TheTime := A_Hour . A_Min . A_Sec ; Create the time format to compare with
If (TheTime == 111400) ; Compare "The Time" with the trigger time of your chosing
{ ; Web API command goes here
msgbox Time Triggered ; Sample trigger command replaced by Web API command.
Return
pm wrote:One idea could be to start a script by Windows task scheduler. In the script make a http vMix web scripting call with the function "KeyPress"
Regards, Patrick This seems to be the simplest and easiest way to do this. Thanks!!
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Another option is to get a midi based clock, or if you have Qlab can trigger on time. Get rtpMidi to transmit it to Vmix and set.
 1 user thanked kjones9999 for this useful post.
