TuesdaysLive
#1 Posted : Thursday, July 26, 2018 11:08:09 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
[EDIT] I've just been testing this on one of our production sites and it does not appear to be working properly. The vmixcall page is not opening. It still works on the non-production site and another of our production sites. It may have to do with a plug-in, or theme, conflict. [/EDIT]
[EDIT 30 July] Found the issue with our production system. A plugin, called USM Premium, was conflicting with the code being used. [/EDIT]
While I am not a coder, this might be of help to some.
First, our site is on Wordpress. To make this code work properly we use a plug-in called 'Embedder'.
Within Wordpress we created an 'embedder' entry with the following code.
Code:
<!DOCTYPE html>
<html>
<head>
  <script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
  <script type="text/javascript">
    $(document).ready(function(){
        $('#myform').submit(function(){ //when form is submitted..
            window.location = "https://www.vmixcall.com/call.aspx?Key=1234567890&Name=" + $('#name').val(); //..get url from the textbox and load that url
            return false; // prevent the form from being submitted
  </script>
</head>
<body>
  <form id="myform">
    <input type="text" id="name" value="" />
    <input type="submit" id="submit" value="Submit" />
  </form>
</body>
</html>
You will need to change the 'Key=1234567890' to the proper password number. The embedder entry is saved with a 'shortcut' name. this name is used, as a, you guessed it, shortcut, on the Wordpress page. You can use any additional stuff you'd like in the page as well (i.e., graphics, text, etc..)
The page, while currently on my test server, very basic and ugly, can be prettied up, if desired. After entering their name and clicking the 'Submit' button they are connected to the call. The call opens in the same window. It should be noted the URL in the address bar, once the call is connected does show the 'vmixcall' url.
thanks 1 user thanked TuesdaysLive for this useful post.
sinc747 on 7/27/2018(UTC)
sinc747
#2 Posted : Friday, July 27, 2018 12:41:42 PM(UTC)
sinc747
Well done! Can't wait to try it.
- Tom
TuesdaysLive
#3 Posted : Friday, July 27, 2018 5:30:11 PM(UTC)
TuesdaysLive
Tom -
I'd love to hear how it works out for you.
As I mentioned, It works on both my test server and one of our production servers. However, we've experienced issues on another production server. I suspect this is because of a theme, or plug-in, conflict. It may also be that the site host either has some incompatible server side services, or is blocking something.
Let me know how you get on.
Rich
sinc747
#4 Posted : Monday, July 30, 2018 3:49:30 PM(UTC)
sinc747
Appears to be working in some brief testing. Still would be nice if it used a URL with my domain instead of vMixCall.com. ;)
- Tom
TuesdaysLive
#5 Posted : Monday, July 30, 2018 4:30:52 PM(UTC)
TuesdaysLive
Well, basically, all the code does is append the name entered by the 'caller' to the URL used by vMixCall.
There are methods of masking the URL in the address bar of a browser to reflect whatever you might want. However, that would take a bit of extra coding.
Glad to hear it is working for you. I'm hoping that others will find it helpful too.
TuesdaysLive
#6 Posted : Wednesday, August 1, 2018 11:43:05 AM(UTC)
TuesdaysLive
After finding and fixing our issue with a plug-in conflict, we've implemented our own 'white label' call front-end, using the code above, with some additional modifications.
This is what it looks like...
sinc747 on 8/1/2018(UTC)
#7 Posted : Wednesday, August 1, 2018 5:25:09 PM(UTC)
I tried your code the other day. Works ok although I modified it to allow users to enter their personal key and prevent them from kicking out a previously logged user.
Guillaume
sinc747 on 9/28/2018(UTC)
TuesdaysLive
#8 Posted: : Wednesday, August 1, 2018 5:30:22 PM(UTC)
TuesdaysLive
Guillaume
That is a very good option to include. Do you plan on sharing the code? However, it should be easy to work in, virtually the same as the 'name' input.
[Edited to add] The inclusion of the 'password', in our case, was not desired as it doesn't change between guests and the chance of them kicking someone is slim. However, it might be interesting to include something like this that generated a code - if one could figure out how to use the locally generated 'password' for the call (since the vMixcall password is generated during the creation of the call input). Or, alternatively, if when one generates a vMixcall input in vMix, the 'password' could be pulled via a script and referenced by the site when a users 'Joins the Call' (if you follow me).
[/Edit]
[Edit 1 Aug] Parsing the saved show file does seem feasible. If one parses for the "VideoCallKey", its value can then be pulled. Thus, one should, theoretically, be able to parse the file, pulling the key value and then create a unique password value for each caller based on the name they enter when they use the connect page. Granted, it is more work than I'm currently willing to put into it, but it would work. [/Edit 1 Aug]
iamralphsutton
#9 Posted : Friday, September 28, 2018 9:44:38 AM(UTC)
iamralphsutton
This is wonderful.
Can you show me the added code to put in a password?
I would really like to add this to my production.
Cormac
#10 Posted : Wednesday, November 28, 2018 10:04:44 AM(UTC)
Cormac
Hi Tuesdayslive. How is this working out for you .are you still using this as a way to brand your call page ?
TuesdaysLive
#11 Posted : Thursday, November 29, 2018 2:35:22 AM(UTC)
TuesdaysLive
It worked very well when we were using it. We've since move from that specific broadcast format into another that no longer requires the caller participation.
sunkast
#12 Posted : Wednesday, April 3, 2019 4:04:24 AM(UTC)
sunkast
I took a stab at this sort of solution but tried to take it a step further. I'm using a reverse proxy so I have my own domain name on top of the vMix Call web site. I also am customizing the appearance to look more modern. But it's essentially the vMix Call web site so ?Code queries will work which is beneficial since I have multiple shows. I can also easily set up quick redirects such as /show1 or /show2 to redirect to the correct code for the show. The "need help" link currently just goes to the vMix Call tutorial on YouTube, but could link to anything really.
justme
#13 Posted : Thursday, April 11, 2019 1:47:41 AM(UTC)
justme
Greece
would be great if VMix devs could come up with changes. so we can add a CNAME/A record on our domain name and use an embed code on our website.
full branding to our stream/brand
koinonia
#14 Posted : Friday, March 20, 2020 12:38:57 PM(UTC)
koinonia
Could you share the code?
Thanks!
Daniel
aircooled76@gmail.com
#15 Posted : Sunday, April 12, 2020 7:23:43 PM(UTC)
I have this working with the URL Redirect method as described at the top here... But not having any luck masking the domain. Also when you hang up the call it goes to vmixcall.com (would prefer it closed the browser window @admins)
Can you share how you would approach masking the URL? I tried an <iframe> method, (https://stackoverflow.com/questions/3982422/full-screen-iframe) but the vMix call page did not load.
I also tried simple domain masking by putting a index.html file redirecting to vmixcall.com (https://www.siteground.com/kb/simple_domain_name_masking/)
No dice.
Would be a nice feature to have to be able to white label it totally. But I suspect there is some security stuff preventing us doing it.
My code (includes option for entering the "invitation code" (vMix call password)
<head>
var urlNumber = $('#number').val()
var urlName = $('#name').val()
var urlString = urlNumber + "&Name=" + urlName
window.location = "https://www.vmixcall.com/call.aspx?Key=" + urlString; //..get url from the textbox and load that url
</script>
</head>
<body>
<form id="myform">
<h4>
<strong> Enter your full name:</strong>
</h4>
<br>
<br>
<h4>
<strong>Enter your invitation code:</strong>
</h4>
<input type="text" id="number" value="" />
<br>
<br>
<input type="submit" id="submit" value="Join Event" />
</form>
</body>
Kovacika
#16 Posted : Friday, April 17, 2020 11:29:21 PM(UTC)
Kovacika
No dice.
<head>
</script>
</head>
<body>
<form id="myform">
<h4>
</h4>
<br>
<br>
<h4>
</h4>
<br>
<br>
</form>
</body>
Is it possible to have the call open in a new window/tab? How would I edit the above code to that?
ayo
#17 Posted : Wednesday, April 22, 2020 9:45:08 PM(UTC)
ayo
Try replacing window.location with window.open()
https://www.w3schools.com/jsref/met_win_open.asp
