Joined: 4/12/2014(UTC) Posts: 4  Location: Trinidad Thanks: 2 times
Hello I have a vmix system using BM Duo 2 capture card using the 4 port as input from sdi sources. I know need 3 additional inputs. Could add another BM Duo 2 card in the system and configure the card as 3 inputs and 1 out?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Already been discussed plenty of times
Short answer is yes if your hardware supports it.
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
DWAM wrote:Already been discussed plenty of times
Short answer is yes if your hardware supports it. In reality, however, it's a pain to work with because rebooting a system with two identical Decklink cards will often result in different initialisation order, causing inputs in vMix to fail on project load. You then need to add the inputs manually again. The right solution would be getting a Quad 2, using your Duo 2's for other purposes.
 1 user thanked niemi for this useful post.
Joined: 6/12/2015(UTC) Posts: 3 Location: South Africa
Originally Posted by: niemi  DWAM wrote:Already been discussed plenty of times
Short answer is yes if your hardware supports it. In reality, however, it's a pain to work with because rebooting a system with two identical Decklink cards will often result in different initialisation order, causing inputs in vMix to fail on project load. You then need to add the inputs manually again. The right solution would be getting a Quad 2, using your Duo 2's for other purposes. Does anyone know if this will fit into an expansion case? like Akiti?
