michaelrb
#1 Posted : Tuesday, July 17, 2018 3:33:39 PM(UTC)
michaelrb
I use vmix social with my twitter account. I have 2 questions:
1) Is there a way to get VMIX Social to only return new comments as they occur, rather than re-cycling back to older comments?
2) I usually stream at the beginning of a show. Is there a way to get Vmix social up and running prior to the start of the stream, or must I start the stream first, then configure vmix social?
#2 Posted : Wednesday, July 18, 2018 3:52:34 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Hi!
1 - Use the Refresh Title: Force an immediate update of the Title using the most recent settings and the most recent content.
- Check if the "Automatically update Title with most recent entry" option under the Title Settings does what you want.
- There is also a "Remove from Queue" option
2 . There is relation at all between "streaming" and "vMix Social"
vMix Social only needs vMix to be running with a social title ready. Just prep everything before the show starts. All settings are saved to a preset so you can even prep before going on location.
vMixSocial manual : https://www.vmix.com/social/help/
Guillaume
michaelrb
#3 Posted : Wednesday, July 18, 2018 5:01:43 PM(UTC)
michaelrb
Thanks for your response. In regard to question 2, what do I place in the queue if the Twitter stream hasn't started yet? ie) The Stream starts at 8pm, I am setting up vmix social at 7:30pm. What goes into the queue?
