VMIX Social - Only new comments
Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
I use vmix social with my twitter account. I have 2 questions:
1) Is there a way to get VMIX Social to only return new comments as they occur, rather than re-cycling back to older comments?
2) I usually stream at the beginning of a show. Is there a way to get Vmix social up and running prior to the start of the stream, or must I start the stream first, then configure vmix social?
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi! 1 - Use the Refresh Title: Force an immediate update of the Title using the most recent settings and the most recent content. - Check if the "Automatically update Title with most recent entry" option under the Title Settings does what you want. - There is also a "Remove from Queue" option 2 . There is relation at all between "streaming" and "vMix Social" vMix Social only needs vMix to be running with a social title ready. Just prep everything before the show starts. All settings are saved to a preset so you can even prep before going on location. vMixSocial manual : https://www.vmix.com/social/help/Guillaume
Thanks for your response. In regard to question 2, what do I place in the queue if the Twitter stream hasn't started yet? ie) The Stream starts at 8pm, I am setting up vmix social at 7:30pm. What goes into the queue?
