Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
Simple question, but I can't see how to do this... I'd like to set an "On Completion" trigger that queues up an input to Preview, ready for me to make a manual transition. I've tried "PreviewInput" - this simply switches the desired input direct to output straight away...
Thanks!
Joined: 12/27/2012(UTC) Views messages in topic : 5,540  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
should be correct though , playing video at end triggers your chosen input to be the preview one
That's what I'd have thought, but it doesn't do it, see attached pic. What actually happens is that the input I want sent to Preview actually goes straight to output. Am I usinfg wrong syntax? AgentPete attached the following image(s):  Image1.png (16kb) downloaded 24 time(s).You cannot view/download attachments. Try to login or register.
remove the zoom transition :-)
the change input is instant but the transition is still ongoing hence it is taking the input you just switched to preview DOnt understand your transition need but if it is realy needed first then delay the start of the previewinput till after the duration of the transition
Brilliant! Thank you so much!
