AgentPete
#1 Posted : Monday, July 16, 2018 12:12:58 PM(UTC)
AgentPete
Was thanked: 9 time(s) in 3 post(s)
Simple question, but I can't see how to do this... I'd like to set an "On Completion" trigger that queues up an input to Preview, ready for me to make a manual transition. I've tried "PreviewInput" - this simply switches the desired input direct to output straight away...
Thanks!
#2 Posted : Monday, July 16, 2018 12:37:01 PM(UTC)
should be correct though , playing video at end triggers your chosen input to be the preview one
AgentPete
#3 Posted : Monday, July 16, 2018 4:28:07 PM(UTC)
AgentPete
That's what I'd have thought, but it doesn't do it, see attached pic.
What actually happens is that the input I want sent to Preview actually goes straight to output. Am I usinfg wrong syntax?
AgentPete attached the following image(s):
#4 Posted : Monday, July 16, 2018 6:14:25 PM(UTC)
remove the zoom transition :-)
the change input is instant but the transition is still ongoing hence it is taking the input you just switched to preview
DOnt understand your transition need but if it is realy needed first then delay the start of the previewinput till after the duration of the transition
AgentPete on 7/17/2018(UTC)
AgentPete
#5 Posted : Tuesday, July 17, 2018 11:24:09 AM(UTC)
AgentPete
Brilliant! Thank you so much!
