Hello I made trrigers: 1-On Transition In ----- OverlayInPut1 ---- 23 Title2blue.xaml 2-On TransitionOut----- OverlayInPut1Off--23 Title2blue.xaml
Where is the choice –Transition- for 23 -Title2blue.xaml
Only FADE???
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
Hi, If you want to change the way an overlay appears you can't to this by triggers. Therefore you have to go to the overlay settings https://www.vmix.com/help21/Overlay2.html and select the transition for your overlay. Best regards Yannick
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Set all 4 overlays the way you want, then use OverlayInput1, OverlayInput2, OverlayInput3, OverlayInput4 to select how your inputs are overlaid
Guillaume
Thank you. I have one more question. Can it be trrigers controlled by changing the contents of a file -- data source?? Example:
change the file content -23 Title2blue.xaml-data source- the frame will be displayed
It's not very clear what you're asking about. Please elaborate a little...
Change in txt in -23 tilte2blue.xaml = appearance of the layer
Not really clearer but if you want to change the text values of your title, you can - use datasources - use the SetText and SetTextColour - use vMix WebController - use vMix UTC For more information, check the manual, it's all explained in it (except UTC for which you can find info and tutorials in this forum) https://www.vmix.com/help21/Guillaume
