RaceGc
#1 Posted : Monday, July 9, 2018 5:14:46 PM(UTC)
RaceGc
Hello
I made trrigers:
1-On Transition In  ----- OverlayInPut1 ---- 23 Title2blue.xaml
2-On TransitionOut----- OverlayInPut1Off--23 Title2blue.xaml
Where is the choice –Transition- for 23 -Title2blue.xaml
Only FADE???
krassesPferd
#2 Posted : Monday, July 9, 2018 5:24:54 PM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
If you want to change the way an overlay appears you can't to this by triggers. Therefore you have to go to the overlay settings https://www.vmix.com/help21/Overlay2.html and select the transition for your overlay.
Best regards
Yannick
#3 Posted : Monday, July 9, 2018 5:36:51 PM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Set all 4 overlays the way you want, then use OverlayInput1, OverlayInput2, OverlayInput3, OverlayInput4 to select how your inputs are overlaid
Guillaume
RaceGc
#4 Posted : Tuesday, July 10, 2018 12:52:30 AM(UTC)
RaceGc
Thank you.
I have one more question.
Can it be trrigers controlled by changing the contents of a file -- data source??
Example:
change the file content -23 Title2blue.xaml-data source- the frame will be displayed
#5 Posted : Tuesday, July 10, 2018 5:09:13 AM(UTC)
It's not very clear what you're asking about. Please elaborate a little...
RaceGc
#6 Posted : Tuesday, July 10, 2018 5:34:18 AM(UTC)
RaceGc
Change in txt in -23 tilte2blue.xaml = appearance of the layer
#7 Posted : Tuesday, July 10, 2018 5:50:39 AM(UTC)
Not really clearer but if you want to change the text values of your title, you can
- use datasources
- use the SetText and SetTextColour
- use vMix WebController
- use vMix UTC
For more information, check the manual, it's all explained in it (except UTC for which you can find info and tutorials in this forum)
Guillaume
Guest (4)
