sequence5
#1 Posted : Wednesday, July 4, 2018 9:51:21 AM(UTC)
sequence5
Hello... i have an issue with my xml data.
i have added it using the data source manager. i can grab some fields easily but need to filter a certain field just to grab only one info from it. Anybody with an idea to fix this pls.
Sample of my XML structure
Code:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<Site>
	<Cinema_strCode>001</Cinema_strCode>
	<Cinema_strName>My circuit group</Cinema_strName>
	<Cinema_strAddress1></Cinema_strAddress1>
	<Cinema_strAddress2></Cinema_strAddress2>
	<Cinema_strAddress3></Cinema_strAddress3>
	<Cinema_strAddress4></Cinema_strAddress4>
	<Cinema_decLatitude>0.000000000000000e+000</Cinema_decLatitude><Cinema_decLongitude>0.000000000000000e+000</Cinema_decLongitude>
	<Operator>
		<CinOperator_strName>site A</CinOperator_strName>
			<Film>
				<Film_strCode>HO00000094</Film_strCode>
				<Film_strTitle>Deadpool 2</Film_strTitle>
				<Film_strOriginalAudio></Film_strOriginalAudio>
				<Sessions>
					<Session>
						<Session_lngSessionId>4913</Session_lngSessionId>
						<Session_strStatus>O</Session_strStatus>
						<Screen_strNum>2</Screen_strNum>
						<Screen_intRemoteSalesCutoff>0</Screen_intRemoteSalesCutoff>
						<Session_intSeatsAvail>65</Session_intSeatsAvail>
						<Session_dtmShowing>2018-07-03T13:00:00</Session_dtmShowing>
						<Session_dtmFeature>2018-07-03T13:20:00</Session_dtmFeature>
						<Session_dtmBusinessDate>2018-07-03T00:00:00</Session_dtmBusinessDate>
						<Session_strSalesChannels>|IVR|CALL|GSALE|WWW|KIOSK|CELL|PDA|POSBK|POS|RSP|</Session_strSalesChannels>
						<Session_strAttributes>2D,Premium,Signature</Session_strAttributes>
						<SType_strDescription>Normal Session</SType_strDescription>
						<Session_strAudioLanguage></Session_strAudioLanguage>
						<Session_strSubtitleLanguage></Session_strSubtitleLanguage>
						<Event_strCode></Event_strCode>
						<Session_strSneakPreviewFlag>N</Session_strSneakPreviewFlag>
						<Session_lngHOMarathonId>0</Session_lngHOMarathonId>
						<Session_lngPlaythruGroupId>0</Session_lngPlaythruGroupId>
					</Session>
					<Session>
						<Session_lngSessionId>4875</Session_lngSessionId>
						<Screen_strNum>1</Screen_strNum>
						<Session_intSeatsAvail>67</Session_intSeatsAvail>
						[color=red]<Session_dtmShowing>2018-07-03T15:20:00</Session_dtmShowing>[/color]
						<Session_dtmFeature>2018-07-03T15:40:00</Session_dtmFeature>
					</Session>
				</Sessions>
			</Film>
I have been able to grab other info but i am not able to grab only the line in red colour [<Session_dtmShowing>2018-07-03T15:20:00</Session_dtmShowing>]
sequence5 attached the following image(s):
vmix data.PNG (33kb) downloaded 55 time(s).
vmix data 2.PNG (204kb) downloaded 56 time(s).
#2 Posted : Wednesday, July 4, 2018 10:07:50 AM(UTC)
Was thanked: 999 time(s) in 827 post(s)
your xml structure is not complete (Not well formed) as posted!
sequence5
#3 Posted : Wednesday, July 4, 2018 10:10:17 AM(UTC)
sequence5
@doggy
that is the structure that the XML is delivered to me.
#4 Posted : Wednesday, July 4, 2018 10:23:10 AM(UTC)
there are no closing tags like for Site , operator or what else that might be missing in the xml you posted
anyway here is a nice little tool to figure out your xpaths :-)
http://xmltoolbox.appspot.com/xpath_generator.html
corporatejames on 7/7/2018(UTC)
sequence5
#5 Posted : Wednesday, July 4, 2018 10:27:16 AM(UTC)
sequence5
while i try this, this is the url to one of the XML http://filmhouseit.com/t...a/VistaSessionslekki.xml
i just want to be able to grab an element in session as description while grabbing the title as header in Vmix
thanks
sequence5
#6 Posted : Wednesday, July 4, 2018 10:35:30 AM(UTC)
sequence5
thanks
i have tried to use the xpath from the site (/Site/Operator/Film/Sessions/Session[1]/Session_dtmFeature) but still had every information in that path populated.
could it be that Vmix does not currently support filtering content from an XML
#7 Posted : Wednesday, July 4, 2018 10:52:20 AM(UTC)
Not an expert but there seems to be a little issue here
testing with http://xmlgrid.net/xpath.html the result is
2018-07-03T13:20:00
while vMix gives you 5 results indeed
doggy attached the following image(s):
sequence5
#8 Posted : Wednesday, July 4, 2018 11:08:45 AM(UTC)
sequence5
2018-07-03T13:20:00
if i use xpath to hit the playing times directly, i will not be able to map it with its Film_strTitle. so i used /Site/Operator/Film
  • to grab everything under each Film. i thought i will be able to filter the times from format like the image
    vmix data 2.PNG (154kb) downloaded 23 time(s).
  • doggy
    #9 Posted : Wednesday, July 4, 2018 11:54:47 AM(UTC)
    maybe open the xml twice?
    Data in a title is not restricted to one datasource table only
    watch out your formatting ! usually just {0}
