Hello... i have an issue with my xml data. i have added it using the data source manager. i can grab some fields easily but need to filter a certain field just to grab only one info from it. Anybody with an idea to fix this pls. Sample of my XML structure Code:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<Site>
<Cinema_strCode>001</Cinema_strCode>
<Cinema_strName>My circuit group</Cinema_strName>
<Cinema_strAddress1></Cinema_strAddress1>
<Cinema_strAddress2></Cinema_strAddress2>
<Cinema_strAddress3></Cinema_strAddress3>
<Cinema_strAddress4></Cinema_strAddress4>
<Cinema_decLatitude>0.000000000000000e+000</Cinema_decLatitude><Cinema_decLongitude>0.000000000000000e+000</Cinema_decLongitude>
<Operator>
<CinOperator_strName>site A</CinOperator_strName>
<Film>
<Film_strCode>HO00000094</Film_strCode>
<Film_strTitle>Deadpool 2</Film_strTitle>
<Film_strOriginalAudio></Film_strOriginalAudio>
<Sessions>
<Session>
<Session_lngSessionId>4913</Session_lngSessionId>
<Session_strStatus>O</Session_strStatus>
<Screen_strNum>2</Screen_strNum>
<Screen_intRemoteSalesCutoff>0</Screen_intRemoteSalesCutoff>
<Session_intSeatsAvail>65</Session_intSeatsAvail>
<Session_dtmShowing>2018-07-03T13:00:00</Session_dtmShowing>
<Session_dtmFeature>2018-07-03T13:20:00</Session_dtmFeature>
<Session_dtmBusinessDate>2018-07-03T00:00:00</Session_dtmBusinessDate>
<Session_strSalesChannels>|IVR|CALL|GSALE|WWW|KIOSK|CELL|PDA|POSBK|POS|RSP|</Session_strSalesChannels>
<Session_strAttributes>2D,Premium,Signature</Session_strAttributes>
<SType_strDescription>Normal Session</SType_strDescription>
<Session_strAudioLanguage></Session_strAudioLanguage>
<Session_strSubtitleLanguage></Session_strSubtitleLanguage>
<Event_strCode></Event_strCode>
<Session_strSneakPreviewFlag>N</Session_strSneakPreviewFlag>
<Session_lngHOMarathonId>0</Session_lngHOMarathonId>
<Session_lngPlaythruGroupId>0</Session_lngPlaythruGroupId>
</Session>
<Session>
<Session_lngSessionId>4875</Session_lngSessionId>
<Screen_strNum>1</Screen_strNum>
<Session_intSeatsAvail>67</Session_intSeatsAvail>
[color=red]<Session_dtmShowing>2018-07-03T15:20:00</Session_dtmShowing>[/color]
<Session_dtmFeature>2018-07-03T15:40:00</Session_dtmFeature>
</Session>
</Sessions>
</Film>
I have been able to grab other info but i am not able to grab only the line in red colour [<Session_dtmShowing>2018-07-03T15:20:00</Session_dtmShowing>] sequence5 attached the following image(s):  vmix data.PNG (33kb) downloaded 55 time(s). vmix data 2.PNG (204kb) downloaded 56 time(s).You cannot view/download attachments. Try to login or register.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
your xml structure is not complete (Not well formed) as posted!
@doggy that is the structure that the XML is delivered to me.
i have tried to use the xpath from the site (/Site/Operator/Film/Sessions/Session[1]/Session_dtmFeature) but still had every information in that path populated. could it be that Vmix does not currently support filtering content from an XML
Not an expert but there seems to be a little issue here testing with http://xmlgrid.net/xpath.html the result is Quote: 2018-07-03T13:20:00
while vMix gives you 5 results indeed doggy attached the following image(s):  filmxml.JPG (56kb) downloaded 37 time(s).You cannot view/download attachments. Try to login or register.
doggy wrote:Not an expert but there seems to be a little issue here testing with http://xmlgrid.net/xpath.html the result is Quote: 2018-07-03T13:20:00
while vMix gives you 5 results indeed if i use xpath to hit the playing times directly, i will not be able to map it with its Film_strTitle. so i used /Site/Operator/Film to grab everything under each Film. i thought i will be able to filter the times from format like the image sequence5 attached the following image(s):  vmix data 2.PNG (154kb) downloaded 23 time(s).You cannot view/download attachments. Try to login or register.
maybe open the xml twice? Data in a title is not restricted to one datasource table only
watch out your formatting ! usually just {0}
