Yannick
#1 Posted : Saturday, June 30, 2018 10:59:57 AM(UTC)
Yannick
Not sure if already available and I just missed it.
I would really like to have a shortcut to open the input settings window.
I´m currently designing my own midi controller and I will add some encoders for the color correction.
However it would be difficult to visualize the settings on the controller itself, and the colour correction tab of the input settings already show all necessary information.
This would of course also be great for the other tabs of the input settings menu.
Peter B
#2 Posted : Saturday, June 30, 2018 1:00:16 PM(UTC)
Peter B
+1
I'm thinking of building a panel too as I have lots of
HP encoders from an old da Vinci Renaissance 888 grading
panel.
I'm also considering one or more of these as it has a ring
for luminance -
https://www.kensington.c...rt-mouse-wired-trackball
I'd have to translate the xy to RGB levels ?
stevespaw
#3 Posted : Thursday, September 20, 2018 8:13:20 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
+1
vvcvvc
#4 Posted : Wednesday, October 24, 2018 6:39:01 AM(UTC)
vvcvvc
Estonia
+1
WaltG12
#5 Posted : Friday, March 11, 2022 10:53:43 AM(UTC)
WaltG12
+1
Inputs all have the same Settings interface, with the same 10 pages.
Right now, the only way to access those 10 pages is to physically click the "Settings" cog on the input & navigate to the page you need.
Shortcuts can tweak most of the settings located therein, but for some (like Auto White Balance) don't have shortcuts & others sometimes need to be adjust manually based on parameters that can't be predicted. For example, when I'm doing a vMix Call or NDI interview, I need to add the guest to my split screen frame. I have it set up so it's perfect if they're dead center in their frame, but if they're slightly off, then I need to go in & pull it left or right by whatever amount they're off by.
This takes time, and, as my guests are doing me a favor by appearing in the first place, I prefer to get them in & out as fast as possible.
It'll always take some time to adjust the settings that need to be adjusted, but having the ability to hit a button on my keyboard to pull up the relevant settings pages (or even just the baseline settings menu for the requisite inputs) will streamline the process by quite a bit.
