Feature Requests
Shortcut to Open Input Settings
Thanks: 2 times Was thanked: 10 time(s) in 9 post(s)
Not sure if already available and I just missed it. I would really like to have a shortcut to open the input settings window.
I´m currently designing my own midi controller and I will add some encoders for the color correction. However it would be difficult to visualize the settings on the controller itself, and the colour correction tab of the input settings already show all necessary information. This would of course also be great for the other tabs of the input settings menu.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
+1 I'm thinking of building a panel too as I have lots of HP encoders from an old da Vinci Renaissance 888 grading panel. I'm also considering one or more of these as it has a ring for luminance - https://www.kensington.c...rt-mouse-wired-trackballI'd have to translate the xy to RGB levels ?
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
+1
Inputs all have the same Settings interface, with the same 10 pages.
Right now, the only way to access those 10 pages is to physically click the "Settings" cog on the input & navigate to the page you need.
Shortcuts can tweak most of the settings located therein, but for some (like Auto White Balance) don't have shortcuts & others sometimes need to be adjust manually based on parameters that can't be predicted. For example, when I'm doing a vMix Call or NDI interview, I need to add the guest to my split screen frame. I have it set up so it's perfect if they're dead center in their frame, but if they're slightly off, then I need to go in & pull it left or right by whatever amount they're off by.
This takes time, and, as my guests are doing me a favor by appearing in the first place, I prefer to get them in & out as fast as possible.
It'll always take some time to adjust the settings that need to be adjusted, but having the ability to hit a button on my keyboard to pull up the relevant settings pages (or even just the baseline settings menu for the requisite inputs) will streamline the process by quite a bit.
Feature Requests
