sickley1
#1 Posted : Monday, June 25, 2018 9:53:00 AM(UTC)
sickley1
It would be hugely helpful to have extensive color correction shortcuts now that we have a good color correction tool built in.
+/- of R,G,B for lift,gamma,gain would allow us to give our camera operators the ability to remotely adjust our camera CC to offload work from the main production tech.
Ittaidv
#2 Posted : Wednesday, June 27, 2018 6:55:03 AM(UTC)
Ittaidv
+1? vMix has become such a powerhouse, that it becomes necesary to be able to work with multiple people on the same machine. I would prefer shortcuts + a possibility to undock CC panels to a seperate screen.
Rinsky
#3 Posted : Wednesday, June 27, 2018 6:57:23 AM(UTC)
Rinsky
+ absolutely!
does anybody know a good controller for this kind of work? x-keys, midi controllers etc. something that would fit?
Ittaidv
#4 Posted : Wednesday, June 27, 2018 7:06:24 AM(UTC)
Ittaidv
Tangent wave, ripple, the palette modular midi controllers, there's plenty of choice.
rinaldo
#5 Posted : Wednesday, June 27, 2018 10:12:31 PM(UTC)
rinaldo
+1
#6 Posted : Wednesday, June 27, 2018 10:21:02 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
BETech
#7 Posted : Thursday, June 28, 2018 10:31:38 AM(UTC)
BETech
Quote: Rinsky “Does anybody know a good controller for this kind of work? x-keys, midi controllers etc. something that would fit?”
Perhaps the Behringer CMD MM-1. The photograph below was taken from an earlier discussion by @pstuart in Feature Requests “Add Waveform Monitor and Vectorscopes”
https://forums.vmix.com/...osts&t=6208&p=3 back in November 2017.
Shortly thereafter, Martin released a preview version of vMix 21 with the color correction shortcuts. A simple hardware interface and for A$180, the MM-1 could be a great alternative, easy to set-up and operate. Just need some labels, a USB Midi cable and vMix. We have not used this particular feature in vMix, as we mostly use the Sony RCP-1500’s, CCU’s and broadcast cameras. Perhaps you may be fortunate to acquire the MM-1 for appraisal purposes, and report your experiences
thanks 1 user thanked BETech for this useful post.
Rinsky on 6/30/2018(UTC)
Rinsky
#8 Posted : Saturday, June 30, 2018 8:07:58 AM(UTC)
Rinsky
Wow, great! Thank you!
Are you already using it this way in your live productions?
sickley1
#9 Posted: : Monday, July 16, 2018 9:31:54 AM(UTC)
sickley1
admin wrote:
This certainly works, but on a touchscreen faders and encoders are a bit unwieldy for minute control, not to mention you would have to setup activators if it were even an option for CC levels. If I were to get a hardware midi controller this would be sufficient, but would take up more space and not be mobile.
It would be easier to use a push button to increase/decrease by a set amount (1, 5, 10, etc).
Rinsky
#10 Posted : Sunday, November 3, 2019 1:58:16 AM(UTC)
Rinsky
Would I have to setup those shortcuts for each input? Is there a way to change the designated input via shortcut? If so, there needs to be a some indicator that show which input I'm correting right now.
richardgatarski
#11 Posted : Sunday, November 3, 2019 2:27:31 AM(UTC)
richardgatarski
I guess you can use "hover" instead of per Input, albeit probably not ideal.
See another FR which I believe is spot on https://forums.vmix.com/...-Functions-for-Shortcuts
