Feature Requests
Color Correction Shortcuts support
It would be hugely helpful to have extensive color correction shortcuts now that we have a good color correction tool built in. +/- of R,G,B for lift,gamma,gain would allow us to give our camera operators the ability to remotely adjust our camera CC to offload work from the main production tech.
+1? vMix has become such a powerhouse, that it becomes necesary to be able to work with multiple people on the same machine. I would prefer shortcuts + a possibility to undock CC panels to a seperate screen.
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
+ absolutely!
does anybody know a good controller for this kind of work? x-keys, midi controllers etc. something that would fit?
Tangent wave, ripple, the palette modular midi controllers, there's plenty of choice.
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 110 time(s) in 71 post(s)
Quote: Rinsky “Does anybody know a good controller for this kind of work? x-keys, midi controllers etc. something that would fit?” Perhaps the Behringer CMD MM-1. The photograph below was taken from an earlier discussion by @pstuart in Feature Requests “Add Waveform Monitor and Vectorscopes” https://forums.vmix.com/...osts&t=6208&p=3 back in November 2017. Shortly thereafter, Martin released a preview version of vMix 21 with the color correction shortcuts. A simple hardware interface and for A$180, the MM-1 could be a great alternative, easy to set-up and operate. Just need some labels, a USB Midi cable and vMix. We have not used this particular feature in vMix, as we mostly use the Sony RCP-1500’s, CCU’s and broadcast cameras. Perhaps you may be fortunate to acquire the MM-1 for appraisal purposes, and report your experiences
 1 user thanked BETech for this useful post.
BETech wrote:Quote: Rinsky “Does anybody know a good controller for this kind of work? x-keys, midi controllers etc. something that would fit?” Perhaps the Behringer CMD MM-1.  Wow, great! Thank you! Are you already using it this way in your live productions?
This certainly works, but on a touchscreen faders and encoders are a bit unwieldy for minute control, not to mention you would have to setup activators if it were even an option for CC levels. If I were to get a hardware midi controller this would be sufficient, but would take up more space and not be mobile. It would be easier to use a push button to increase/decrease by a set amount (1, 5, 10, etc).
Would I have to setup those shortcuts for each input? Is there a way to change the designated input via shortcut? If so, there needs to be a some indicator that show which input I'm correting right now.
Feature Requests
