4 simultaneously outputs problem
Hello I am having a problem. I use the DeckLink Quad 2 for importing cameras and gigabyte 1050Ti for output, I use the 4K license The configuration that is use is the following Fullscreen 1 Display 2 source input 1
Fullscreen 2 Display 3 source input 2
Record/stream/external Input 8
The problem that i face with this configuration is tha fullsceen 1 keeps changing to output and if i try to show to external output any other input it does not work
Has anybody else faced the same problem? Thank you
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
Either Fullscreen 1 or Output 1 must always be set to Output. Otherwise the main mix in vMix would not end up anywhere!
So if you want Input 8 in the record/stream/external, set that to Output and switch the Input 8 to Output/Program.
Martin vMix
