givros
#1 Posted : Friday, June 29, 2018 4:12:59 AM(UTC)
givros
Hello
I am having a problem.
I use the DeckLink Quad 2 for importing cameras and gigabyte 1050Ti for output, I use the 4K license
The configuration that is use is the following
Fullscreen 1
Display 2 source input 1
Fullscreen 2
Display 3 source input 2
Record/stream/external
Input 8
The problem that i face with this configuration is tha fullsceen 1 keeps changing to output and if i try to show to external output any other input it does not work
Has anybody else faced the same problem?
Thank you
#2 Posted : Friday, June 29, 2018 4:22:47 AM(UTC)
Was thanked: 4759 time(s) in 1633 post(s)
Either Fullscreen 1 or Output 1 must always be set to Output.
Otherwise the main mix in vMix would not end up anywhere!
So if you want Input 8 in the record/stream/external, set that to Output and switch the Input 8 to Output/Program.
givros on 6/29/2018(UTC)
givros
#3 Posted : Friday, June 29, 2018 4:26:06 AM(UTC)
givros
Than you!!!
