Jachgu
#1 Posted : Saturday, June 23, 2018 1:33:34 PM(UTC)
Jachgu
Computers
Asus ROG with i7 1050ti 4g, 16GB ram, Win 10 (running vmix)
HP Laptop just general laptop nothing special with Win 10 (running powerpoint and NDI desktop capture)
PTZ optics camera
All connected by ethernet to one 4 port router (no internet, just LAN)
Ok the issue
If there is mouse input or screen changes on the NDI desktop input it causes glitches on the camera streaming input.
Any tips??
Jason
Jachgu attached the following image(s):
TuesdaysLive
#2 Posted : Saturday, June 23, 2018 2:34:20 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
What kind of router?
thanks 1 user thanked TuesdaysLive for this useful post.
Jachgu on 6/24/2018(UTC)
Jachgu
#3 Posted : Saturday, June 23, 2018 2:49:47 PM(UTC)
Jachgu
Tried three
Netgear WNR2000v3
Belkin FD59231-4v1
Netgear WGR614v7
Was thinking that might be the issue too
What type of router is best?
Jason
sinc747
#4 Posted : Saturday, June 23, 2018 5:12:47 PM(UTC)
sinc747
Was thanked: 203 time(s) in 169 post(s)
Don't know about the Belkin, but the two Netgear routers appear to be 100/10 not gigabit.
A NDI video source will use 100-120 Mbps of bandwidth. If you're on a 100/10 switch or router, it will overload immediately.
Try a Gigabit router or switch.
- Tom
SportsNetUSA.net
#5 Posted : Saturday, June 23, 2018 5:28:04 PM(UTC)
SportsNetUSA.net
If the model number on the Belkin is actually F5D9231-4, then it's a 10/100 also, not a Gigabit.
thanks 1 user thanked SportsNetUSA.net for this useful post.
Jachgu
#6 Posted : Saturday, June 23, 2018 5:44:39 PM(UTC)
Jachgu
It seems all I have 10/100 routers upon inspection.
Thanks for the tips
Ill go looking for a gigabit router now :)
THANKS AGAIN!!
Jason
mjgraves
#7 Posted : Saturday, June 23, 2018 7:03:56 PM(UTC)
mjgraves
Don't waste the money. All you need is a gigabit switch to use downstream of the router. Those are dirt cheap.
Jachgu
#8 Posted : Saturday, June 23, 2018 8:53:59 PM(UTC)
Jachgu
Didn't spend a thing. Realized I personally had a cable modem 4 port gigabit router combo And newly gifted second hand router wifi combo 4 port gigabit router that I switched out and boom !! It's streaming perfectly.
I'm ready for test run!!
Thanks everyone for the input!!!!
.. Jason
