#1 Posted : Friday, June 22, 2018 4:51:21 AM(UTC)
Hi All,
In recent months, we have discovered a number of bundled pieces of software with laptops and PCs that
can interfere with the graphics card and cause problems with programs like vMix.
We've already taken steps to turn off GeForce Experience and Asus Sonic Suite (Sonic Radar),
but these are just the tip of the iceberg.
Enter: vMix Diagnostics Beta!
https://www.vmix.com/download/vmixdiagnostics.zip
This is a free utility that will do a quick scan to identify and report programs that run in the middle of vMix and the graphics card, potentially reducing performance and causing other issues.
Instructions
Download the above zip file and extract it to a folder on your computer.
Run the vMixDiagnostics program, optionally select the graphics card to use and click Scan.
Who should try this
Anybody that is experience flickering issues or high render times should give this app a try and see what it says.
Or if you are just curious if you have any software installed that might cause problems in the future.
This utility is completely non-invasive and informational only, so you don't need to worry about it disabling software on its own, that is up to you!
As always, your feedback is appreciated.
Thanks,
thanks 12 users thanked admin for this useful post.
mburel1980 on 6/22/2018(UTC), doggy on 6/22/2018(UTC), BETech on 6/22/2018(UTC), SportsNetUSA.net on 6/22/2018(UTC), corporatejames on 6/23/2018(UTC), DWAM on 6/23/2018(UTC), avsoundguy on 6/23/2018(UTC), Ario on 6/23/2018(UTC), PFBM on 6/23/2018(UTC), niemi on 6/24/2018(UTC), monamiga on 6/24/2018(UTC), seb666 on 7/6/2018(UTC)
rudyengels
#2 Posted : Friday, June 22, 2018 2:56:16 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Strange thing. On my 17" laptop (nVidia 1070) no problem (just warning about BitDefender). On my 15" laptop (nVidia 1050Ti) it only sees the Intel HD Graphics 630.
ask
#3 Posted : Friday, June 22, 2018 7:33:22 PM(UTC)
ask
Does it require a 64bit OS? Fails on a 32bit win10 install. Andrew.
SportsNetUSA.net
#4 Posted : Friday, June 22, 2018 8:34:38 PM(UTC)
SportsNetUSA.net
On my ASUS ROG G751J - NVIDIA GTX 970M - Win10 Pro
No background Graphics Card applications detected.
The following applications may still interfere with vMix, but should not impact the graphics performance:
NVIDIA Windows WDDM D3D driver: (C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvd3dumx.dll)
On my Dell Lattitude E6530 - Intel HD Graphics 4000 - Win7 Pro
NVIDIA D3D shim drivers: (C:\Windows\system32\nvinitx.dll)
NVIDIA D3D shim drivers: (C:\Windows\system32\NV\igdumd64.dll)
-- NVIDIA NVS 5200M not detected in vMix
#5 Posted : Friday, June 22, 2018 9:29:43 PM(UTC)
On Optimus laptops you will need to right click the application and select run using the dedicated graphics
for it to see the devices.
Also, I should have mentioned, this is a 64bit only application.
ask on 6/22/2018(UTC)
clafarge
#6 Posted : Friday, June 22, 2018 11:01:14 PM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
Better add MSI Dragon Center to the list: https://forums.vmix.com/...aspx?g=posts&t=15999
zenvideo
#7 Posted : Saturday, June 23, 2018 3:43:54 AM(UTC)
zenvideo
On my MSI GE72 6QD I get
Nahimic: (C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2DevProps.dll)
Nahimic2: (C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2OSD.dll)
Interestingly, some part of the Nahimic v1 software (that was pre-installed on this laptop) caused my NDI apps to crash when using the NDI v3.5.5 DLL, whereas NDI v3.5.1 had been fine. Took a while to track down what was causing the NDI crash, and that it was not something in the NDI DLL itself, but the crashes went away after removing the original Nahimic software and subsequently finding a newer version v2.321 which is what's currently installed.
ben1000
#8 Posted : Saturday, June 23, 2018 3:19:37 PM(UTC)
ben1000
Howdy...
I tried to download the new beta vMix Diagnostic tool from the link in the above thread, but when I do, Windows 10 says it contains a virus:
Trojan:Win32/Sprisky.U!cl
Anyone else saw this? Can the admins confirm it's ok?
Best,
Ben
#9 Posted : Saturday, June 23, 2018 9:23:12 PM(UTC)
Hi Ben,
The file is clean as per VirusTotal:
https://www.virustotal.c...582af14470b4f8/detection
#10 Posted : Tuesday, June 26, 2018 4:44:24 AM(UTC)
A slightly updated version of vMix Diagnostics is now included with the latest vMix update.
Also supports 32 bit Windows.
corporatejames on 6/26/2018(UTC), MartinJudkins on 6/27/2018(UTC)
