Feature Requests
Ability to Map ANY Excel cell to ANY text field
I use Excel integration all the time, and it would be nice to have a way to map say cell B4 to the "headline" text, and F6 to the "line 2 text". I would use this for full screen standing boards with more than one entry, you have a bunch of teams, their point totals, wins, all is currently stored as a chart in Excel, but I can only use one line at a time the way the Excel Data source is set up.
Joined: 3/7/2012(UTC) Posts: 2,675  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ spencerm24
This is already possible unless I have misunderstood you. Each text field in an XAML Title can be mapped to its own data source, it can be from the same sheet or a completely different data source.
IceStream wrote:@ spencerm24
Ice hmmmm, perhaps I can't figure out how to map multiple data points on a single data source. I have a chart that looks like this: TEAM 1 4 1 1 8 TEAM 2 3 3 1 7 TEAM 3 2 4 0 5 TEAM 4 1 4 1 4 TEAM 5 0 5 1 1 I want to be able to map all those to different text fields, and using data source, unless I add a different data source for each line, I can't find a way to do this. I'd have to have 5 data sources in this example. It lets me select the column I use, but not the row. In the above example, the ability to select the row as well is critical. For larger graphics with 10-12 lines, that would mean 10-12 data sources.
@ spencerm24
You can convert rows to columns in the data source settings. It might not be what you want or easily managed, but it is possible.
Joined: 12/27/2012(UTC) Posts: 5,459  Location: Belgium Thanks: 312 times Was thanked: 1009 time(s) in 831 post(s)
Ice is what we do for a ranking display
Feature Requests
