castfeeder
#1 Posted : Tuesday, June 12, 2018 1:58:51 PM(UTC)
castfeeder
I'm on V21.0.0.44 x64 (HD). Using the USB2.0 HD UVC Webcam driver. Adding camera input and selecting logitech webcam c930e (1920x1080, 29.97p, vid format default) I get the error message " Add new input/Unspecified error". Strangely I have another preset set up where the c930e camera appears without any problem with the same settings. Any thoughts as to why it won't work in a input?
Mari
#2 Posted : Tuesday, June 12, 2018 3:22:13 PM(UTC)
Mari
Netherlands
Try one of the other options for vid format. Else remove driver and try again...
castfeeder
#3 Posted : Tuesday, June 12, 2018 4:00:17 PM(UTC)
castfeeder
Thanks Mari. I've tried uninstalling UVC driver, restarted and same error message appeared at input. Tried each vid format including YUY2 and MJPG, same error message.
castfeeder
#4 Posted : Wednesday, June 13, 2018 8:29:49 AM(UTC)
castfeeder
Resolved! Adding C930e camera input, audio device has by default "microphone (logitech C930e)", if I select audio device as 'none', it accepts the camera. Strange, never had that one before.
