	Hardware Compatibility
	Logitech C930e won't add as camera in v21
  Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
                I'm on V21.0.0.44 x64 (HD). Using the USB2.0 HD UVC Webcam driver. Adding camera input and selecting logitech webcam c930e (1920x1080, 29.97p, vid format default) I get the error message " Add new input/Unspecified error". Strangely I have another preset set up where the c930e camera appears without any problem with the same settings. Any thoughts as to why it won't work in a input?
 Joined: 2/14/2016(UTC) Posts: 117  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
                Try one of the other options for vid format. Else remove driver and try again...
                Thanks Mari. I've tried uninstalling UVC driver, restarted and same error message appeared at input. Tried each vid format including YUY2 and MJPG, same error message.
                Resolved! Adding C930e camera input, audio device has by default "microphone (logitech C930e)", if I select audio device as 'none', it accepts the camera. Strange, never had that one before.
