#1 Posted : Thursday, May 17, 2018 2:16:21 AM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
sinc747 on 5/31/2018(UTC), avsoundguy on 5/31/2018(UTC)
#2 Posted : Tuesday, May 22, 2018 1:42:08 AM(UTC)
21.0.0.42
* Fixed memory issue with VST3 plugins, especially with latest Windows 10 update
* Video frame delay now supported on NDI and VLC inputs
* Added "Custom Multi-Bitrate" dropdown option in streaming destinations.
This allows custom URLs and Stream Keys for each stream without using separate streaming instances for each which may cause problems with some CDNs
* Fixed issue in vMix Social where Overlay was sometimes triggered before content in title had been updated
thanks 4 users thanked admin for this useful post.
ON.tv Channels on 5/22/2018(UTC), pabloloc on 5/24/2018(UTC), sinc747 on 5/31/2018(UTC), avsoundguy on 5/31/2018(UTC)
#3 Posted : Thursday, May 31, 2018 1:28:15 AM(UTC)
21.0.0.43
* Improved performance of local desktop capture on desktop PCs
* Added support for Sony BRC series PTZ cameras using VISCA over IP
* Fixed issue with audio only NDI outputs not appearing
thanks 6 users thanked admin for this useful post.
corporatejames on 5/31/2018(UTC), ask on 5/31/2018(UTC), sinc747 on 5/31/2018(UTC), avsoundguy on 5/31/2018(UTC), PrepSpin on 6/1/2018(UTC), stevemol on 6/2/2018(UTC)
#4 Posted : Saturday, June 2, 2018 6:14:27 AM(UTC)
21.0.0.44
* Additional bug fixes for Sony BRC series VISCA over IP support
* Will now no longer attempt to reconnect to Facebook streams that have expired
thanks 5 users thanked admin for this useful post.
corporatejames on 6/2/2018(UTC), sinc747 on 6/2/2018(UTC), avsoundguy on 6/3/2018(UTC), GeorgeR on 6/9/2018(UTC), monamiga on 6/9/2018(UTC)
#5 Posted : Tuesday, June 12, 2018 2:03:12 AM(UTC)
21.0.0.45
* Fixed issue with SetAudioFade when used with List input
* Improved CPU usage accuracy
* CPU/GPU warnings are now disabled by default
Can be enabled under Settings -> Performance.
When disabled, will still be reported in the logs to help assist our support team.
corporatejames on 6/12/2018(UTC), BETech on 6/12/2018(UTC), sinc747 on 6/12/2018(UTC), avsoundguy on 7/10/2018(UTC)
#6 Posted : Tuesday, June 26, 2018 4:41:33 AM(UTC)
21.0.0.47
* vMix Diagnostics is now included with install and can be found from the "hamburger" menu in vMix
or in the start menu.
Detects any background applications that may interfere with the graphics card causing errors, flickering and performance issues.
* Fixed replay bug when trying to play back incomplete events.
* Fixed issue where PTZ Optics ZCAM provider did not appear in PTZ dropdown list.
mburel1980 on 6/26/2018(UTC), corporatejames on 6/26/2018(UTC), sinc747 on 6/26/2018(UTC), raugert on 7/4/2018(UTC), ON.tv Channels on 7/5/2018(UTC), avsoundguy on 7/10/2018(UTC)
#7 Posted : Tuesday, July 10, 2018 3:17:22 AM(UTC)
21.0.0.49
* Added low latency 4K support for Logitech BRIO through new MediaFoundation support.
This can be used by selecting the new "Logitech BRIO MF" dropdown option when adding a camera input.
* Added NV12 video format support for Magewell devices.
This is useful for 4K60 capture as it reduces dropped frames by lowering the PCI bandwidth needed.
* Fixed bug in Replay where disconnected sources would not automatically resume recording.
mjgraves on 7/10/2018(UTC), avsoundguy on 7/10/2018(UTC), madness on 7/11/2018(UTC), corporatejames on 7/12/2018(UTC), Bruno Mancini on 7/12/2018(UTC), sinc747 on 7/26/2018(UTC)
#8 Posted : Friday, July 20, 2018 12:58:58 AM(UTC)
21.0.0.50
* Improved recording quality in Replay when using 1080p sources.
To enable, select 200 Mbps as the bitrate before adding the replay session to vMix.
Previously 200 Mbps would only have an effect on Interlaced sources.
* Relaxed video format restrictions with AJA capture devices.
New rules are as follows:
1. All outputs must be in the same "clock family". (29.97/59.94 or 50/25)
2. Port 1 must be in same clock family as outputs if used as an input channel.
3. Ports 2+ will accept any input format.
* Fixed some rare issues with AVI codecs
corporatejames on 7/20/2018(UTC), kgoodyer on 7/21/2018(UTC), ON.tv Channels on 7/22/2018(UTC), sinc747 on 7/26/2018(UTC), avsoundguy on 9/11/2018(UTC)
#9 Posted : Wednesday, July 25, 2018 12:05:42 AM(UTC)
21.0.0.51
* Fixed issue logging in to Facebook with Two Factor Authentication in some countries
* Updated Facebook permissions to support latest security requirements for Groups
* Fixed issue where vMix Call return video freezes or becomes garbled when changing sources
* Fixed rare error that may occur when closing vMix on slower systems
ON.tv Channels on 7/25/2018(UTC), corporatejames on 7/25/2018(UTC), ask on 7/25/2018(UTC), sinc747 on 7/26/2018(UTC), slb5146 on 7/26/2018(UTC), avsoundguy on 9/11/2018(UTC)
#10 Posted : Monday, July 30, 2018 11:40:18 PM(UTC)
21.0.0.53
* Fixed support for streaming to Facebook Groups.
This requires a new approval process with instructions found below:
https://www.vmix.com/fbgroups
* Fixed auto creation of Facebook streams when description was left bank
corporatejames on 7/31/2018(UTC), ask on 7/31/2018(UTC), sinc747 on 7/31/2018(UTC), avsoundguy on 9/11/2018(UTC)
#11 Posted : Wednesday, August 15, 2018 4:19:42 AM(UTC)
21.0.0.55
* Recalibrated skin tone line in Vectorscope for better accuracy
* Added new recommended Periscope streaming quality presets
* Fixed some issues with new Kona HDMI card and added support for the following modes:
1. Up to 4K60 on Input 1 + 2x HD on Input 3 and 4.
2. Up to 4K60 on Input 1 + 4K30 on Input 2
3. Up to HD60 on Inputs 1,2,3 and 4.
* Activators input selection dropdown increased to 300 inputs to match shortcuts.
Vuurmannetje on 8/15/2018(UTC), ON.tv Channels on 8/15/2018(UTC), BETech on 8/15/2018(UTC), sinc747 on 8/15/2018(UTC), avsoundguy on 9/11/2018(UTC)
#12 Posted : Friday, September 7, 2018 1:42:29 AM(UTC)
21.0.0.56
* Fixed issue with ButtonPress activator on the APC Mini
* Fixed List tab not refreshing when saving Video Delay clips to a list
* Added error messages describing when Camera or Microphone access is disabled in Windows Privacy settings
* Improved compatibility with new NDI support in Skype.
DWAM on 9/7/2018(UTC), ON.tv Channels on 9/7/2018(UTC), sinc747 on 9/7/2018(UTC), corporatejames on 9/8/2018(UTC), avsoundguy on 9/11/2018(UTC), chiscort on 9/13/2018(UTC)
#13 Posted : Tuesday, October 23, 2018 12:14:06 PM(UTC)
21.0.0.57
* Fixed login issue with Twitch
* Added workaround for issue with codecs that don't correctly support more than 4GB of memory
* Fixed frame offset issue during Replay transitions
* Fixed ColourCorrectionReset shortcut not correctly resetting Gamma
* Fixed issue with VST3 plugins that have duplicate names
* Fixed issue with FFMPEG recording 29.97p in EU.
* Fixed vMix Social issue when Windows region set to Turkey.
thanks 9 users thanked admin for this useful post.
SHMD on 10/23/2018(UTC), ask on 10/23/2018(UTC), corporatejames on 10/23/2018(UTC), PFBM on 10/23/2018(UTC), raugert on 10/26/2018(UTC), ON.tv Channels on 10/27/2018(UTC), monamiga on 10/28/2018(UTC), AngusFindlay on 10/29/2018(UTC), sinc747 on 12/1/2018(UTC)
#14 Posted : Monday, November 19, 2018 3:53:37 PM(UTC)
21.0.0.58
Fixed GPU render time issue when using the List input after a long period of time.
Mari on 11/19/2018(UTC), prass on 11/20/2018(UTC), STADIORADIO on 11/29/2018(UTC), Reinaldo on 12/1/2018(UTC), sinc747 on 12/1/2018(UTC)
#15 Posted : Friday, November 30, 2018 12:48:54 PM(UTC)
21.0.0.59
* Added support for alpha channel when using XSplit VCam
* Improved performance when using API to update multiple text fields
Reinaldo on 12/1/2018(UTC), sinc747 on 12/1/2018(UTC), stigaard on 12/8/2018(UTC), corporatejames on 12/9/2018(UTC)
#16 Posted : Thursday, December 27, 2018 2:49:47 PM(UTC)
21.0.0.60
vMix Social 5 included with the following updates:
* New Twitch Chat support
* Support for YouTube SuperChat messages, these will show a prefix in the web interface to identify
these from normal chat messages. This prefix will then be removed before sending to vMix.
* Fixed issue with missing photos in Facebook due to new security update.
* Instagram has now been discontinued due to Instagram policies outside our control.
thanks 7 users thanked admin for this useful post.
sinc747 on 12/27/2018(UTC), BETech on 12/27/2018(UTC), Chircanu on 12/27/2018(UTC), ask on 12/28/2018(UTC), ON.tv Channels on 12/31/2018(UTC), Tat on 1/2/2019(UTC), rowby on 1/7/2019(UTC)
