Joined: 1/13/2010(UTC) Posts: 5,375  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
21.0.0.42
* Fixed memory issue with VST3 plugins, especially with latest Windows 10 update * Video frame delay now supported on NDI and VLC inputs * Added "Custom Multi-Bitrate" dropdown option in streaming destinations. This allows custom URLs and Stream Keys for each stream without using separate streaming instances for each which may cause problems with some CDNs * Fixed issue in vMix Social where Overlay was sometimes triggered before content in title had been updated
 4 users thanked admin for this useful post.
21.0.0.43
* Improved performance of local desktop capture on desktop PCs * Added support for Sony BRC series PTZ cameras using VISCA over IP * Fixed issue with audio only NDI outputs not appearing
 6 users thanked admin for this useful post.
21.0.0.44
* Additional bug fixes for Sony BRC series VISCA over IP support * Will now no longer attempt to reconnect to Facebook streams that have expired
 5 users thanked admin for this useful post.
21.0.0.45
* Fixed issue with SetAudioFade when used with List input
* Improved CPU usage accuracy
* CPU/GPU warnings are now disabled by default Can be enabled under Settings -> Performance. When disabled, will still be reported in the logs to help assist our support team.
21.0.0.47
* vMix Diagnostics is now included with install and can be found from the "hamburger" menu in vMix or in the start menu. Detects any background applications that may interfere with the graphics card causing errors, flickering and performance issues.
* Fixed replay bug when trying to play back incomplete events. * Fixed issue where PTZ Optics ZCAM provider did not appear in PTZ dropdown list.
21.0.0.49
* Added low latency 4K support for Logitech BRIO through new MediaFoundation support. This can be used by selecting the new "Logitech BRIO MF" dropdown option when adding a camera input.
* Added NV12 video format support for Magewell devices. This is useful for 4K60 capture as it reduces dropped frames by lowering the PCI bandwidth needed.
* Fixed bug in Replay where disconnected sources would not automatically resume recording.
21.0.0.50
* Improved recording quality in Replay when using 1080p sources. To enable, select 200 Mbps as the bitrate before adding the replay session to vMix. Previously 200 Mbps would only have an effect on Interlaced sources.
* Relaxed video format restrictions with AJA capture devices. New rules are as follows: 1. All outputs must be in the same "clock family". (29.97/59.94 or 50/25) 2. Port 1 must be in same clock family as outputs if used as an input channel. 3. Ports 2+ will accept any input format.
* Fixed some rare issues with AVI codecs
21.0.0.51
* Fixed issue logging in to Facebook with Two Factor Authentication in some countries * Updated Facebook permissions to support latest security requirements for Groups * Fixed issue where vMix Call return video freezes or becomes garbled when changing sources * Fixed rare error that may occur when closing vMix on slower systems
21.0.0.53* Fixed support for streaming to Facebook Groups. This requires a new approval process with instructions found below: https://www.vmix.com/fbgroups* Fixed auto creation of Facebook streams when description was left bank
21.0.0.55
* Recalibrated skin tone line in Vectorscope for better accuracy * Added new recommended Periscope streaming quality presets * Fixed some issues with new Kona HDMI card and added support for the following modes: 1. Up to 4K60 on Input 1 + 2x HD on Input 3 and 4. 2. Up to 4K60 on Input 1 + 4K30 on Input 2 3. Up to HD60 on Inputs 1,2,3 and 4.
* Activators input selection dropdown increased to 300 inputs to match shortcuts.
21.0.0.56
* Fixed issue with ButtonPress activator on the APC Mini * Fixed List tab not refreshing when saving Video Delay clips to a list * Added error messages describing when Camera or Microphone access is disabled in Windows Privacy settings * Improved compatibility with new NDI support in Skype.
21.0.0.57
* Fixed login issue with Twitch * Added workaround for issue with codecs that don't correctly support more than 4GB of memory * Fixed frame offset issue during Replay transitions * Fixed ColourCorrectionReset shortcut not correctly resetting Gamma * Fixed issue with VST3 plugins that have duplicate names * Fixed issue with FFMPEG recording 29.97p in EU. * Fixed vMix Social issue when Windows region set to Turkey.
 9 users thanked admin for this useful post.
21.0.0.58
Fixed GPU render time issue when using the List input after a long period of time.
21.0.0.59
* Added support for alpha channel when using XSplit VCam * Improved performance when using API to update multiple text fields
21.0.0.60
vMix Social 5 included with the following updates:
* New Twitch Chat support * Support for YouTube SuperChat messages, these will show a prefix in the web interface to identify these from normal chat messages. This prefix will then be removed before sending to vMix. * Fixed issue with missing photos in Facebook due to new security update. * Instagram has now been discontinued due to Instagram policies outside our control.
 7 users thanked admin for this useful post.
